Vlad
Vlad’s si
- May 7, 2017
- 98
- 124
- Buffalo Grove iL
- 2017 civic si
What do u think about the interior
My winter set up 205/50r17
It is not only cheaper. It's better!It doesn't really matter the smaller diameter wheels are generally cheaper but for snow traction the diameter of your wheel doesn't matter though a smaller wheel will give more sidewall to cushion potholes if that's a problem in your area
https://www.thoughtco.com/why-downsize-your-winter-wheels-3234481A smaller and narrower tire has better grip and performance in snow or ice. This is both because the smaller tire cuts through snow more effectively and because the weight of the car is pressing on a more focused set of contact patches.
I'm also in ON and I currently have 17" winter tires on my si. Steelies were bought from Canadian Tire and tires from a separate shop.I am stuck.
I called 2 Honda dealerships and they both told me that I could not downgrade to 17-inch alloy wheels. The only choice is to buy 18-inch winter tires and use the OE 18-inch alloys.
On the other hand, some of you guys are doing the 17-inch.
Of course 17" fit on the SI. Just need to watch the offset.I am stuck.
I would think so.Of course 17" fit on the SI. Just need to watch the offset.
I am going for this one. It comes in black as well.Would 8" wide with offset 40mm fit? I didn't see anything in 7-7.5 that I liked.
I'm considering these:
https://www.tirerack.com/wheels/Whe...an&autoYear=2017&autoModClar=&tire=25HR7XI3XL
Still trying to decide between the Michelin XI3 or the Bridgestone WS80 in 225/50/17
I'm going with the 225 because that's what tire rack recommended. Plus I think I'll like it for everyday driving. It doesn't snow every day here in NJ, I'll say about 3-4 snow storms during the whole season. Work is only 1 town over which takes me 12 minutes.I am going for this one. It comes in black as well.
https://www.tirerack.com/wheels/Whe...del=Civic+Si+Sedan&autoYear=2017&autoModClar=
I originally wanted the 17x7 with 45mm offset (same as the Touring) but Enkei suggested 17 x 7 with 38mm offset. As for tires. I am in the same boat as you; deciding between the WS80 and X-Ice3. Why 225-50-17? I think I would go for 215-50-17. The difference in speedometer with 215-50-17 is only +0.4% and also thinner tire is better for winter 9less snow to plow).
I see you are familiar with Tirerack. There are comparison charts in 1010tires as well:
http://www.1010tires.com/Tires/Reviews
I see. I just talked to Tirerack yesterday and he also recommended 225. We discussed 215 and he actaully agreed.I'm going with the 225 because that's what tire rack recommended. Plus I think I'll like it for everyday driving. It doesn't snow every day here in NJ, I'll say about 3-4 snow storms during the whole season. Work is only 1 town over which takes me 12 minutes.
Yes you are better off with smaller width tires.I see. I just talked to Tirerack yesterday and he also recommended 225. We discussed 215 and he actaully agreed.
I am in Toronto and have long work commute, thinner tires would be helpful. His is 5e reason I downsize to 17-inch. To have a skinner tire and respect the overall diameter.
