rhino
- jacob
- Jul 15, 2019
- 5
- 5,329
- 6,643
- Weeb land!
- 2015 sr5 access cab, 98 civic hx ej7, 2003 KLX400s
- Vehicle Showcase
i gotcha i let the dealer do my oil changes its only 30 bucks for oil change fluid fill and tire rotation. ill try and see about the metal bars thou that would help if i ever get aftermarket wheels and exhaust so i can do it my selfThere should be a steel bar on the bottom of the car a little past the side skirt plastic close to each wheel. That entire steel bar should be safe if you don't use the weld line. Our Civics cannot be put on most 2 pillar lifts because our cars are too short and wide for them. My car would only go on the lifts with some ghetto wood block spacers to have the car sit directly on the lift bar instead of its contact patch. If you are doing an oil change, maybe it is possible to drive one wheel on the sidewalk curb in you neighborhood and just have the car slanted so you can do it risk free if your sidewalk curb isn't gonna break with 1500 lbs on them
