Si TIP for fk7
FK7NorCali
Andrew
San Francisco
2018 Honda Civic Sport hatchback
Will the si turbo inlet pipe bolt up to my Civic Sport? Looking to upgrade without going 27won.
Honda Civic 10th gen Si TIP for fk7 honda-civic-turbo-inlet-pipe-back-labeled
xjoshuax89
Josh
Maryland
Yes but why?
FK7NorCali
Andrew
San Francisco
The SI comes with a wider inlet pipe. I live in california and can only use smog approved carb parts or honda parts. This is my alternative to 27won.
Yes I could remove it every few years for smog but the install looks like it's something I won't love doing over and over again.[/QUOTE]
xjoshuax89
Josh
Maryland
[/QUOTE]
The gains you get from the Si inlet pipe will be so minimal especially on a stock turbo. Maybe 1hp if that.
FK7NorCali
Andrew
San Francisco
You don't think it's worth it? If it's that little maybe I'll think twice about it.
xjoshuax89
Josh
Maryland
If you reference the 27won tip blogs they note the difference of the non si with the si. The delta change is miniscule.
Even the 27won tip on stock turbo only gained around 2 hp on si
FK7NorCali
Andrew
San Francisco
Thanks man I'll check out the read. I'll probably just get a ptp inlet blanket and call it a day.
