froidpython
Any ideas what the 0-60 will be? Do you think it will be under 6.3 seconds?
I hope so or at least around there if they want to separate the Si trim from the other 1.5T offerings The 8th Gen Si I think was 6.2 and the 9th Gen Si might have been 6.3?Any ideas what the 0-60 will be? Do you think it will be under 6.3 seconds?
Can you show me how you came up with that? That seems way off.If you plug in the gear ratios including final drive and tire diameter in a calculator, shifting at 7000RPM pegs second gear at 43 MPH, so you still need to reach for 3rd to get to 60 so it will probably be around 6.3~ ish seconds, maybe quicker depending on the launch and shift action by the driver.
Something is off here.If you plug in the gear ratios including final drive and tire diameter in a calculator, shifting at 7000RPM pegs second gear at 43 MPH, so you still need to reach for 3rd to get to 60 so it will probably be around 6.3~ ish seconds, maybe quicker depending on the launch and shift action by the driver.
I think I figured it out. You must've entered 2.80 instead of 2.08 for 2nd gear.Can you show me how you came up with that? That seems way off.
The gearing calculator I used shows 58mph at redline at the top of 2nd gear.
The redline is 6500 though; I would expect the rev limiter to kick in before 7000?...shifting at 7000RPM...
