Should i lower my vehicle or not?
Autocube
Daniel James
Philippines
Honda Civic 1.8E
Hi, my current set up is 18x9.5 et35 on a 245/40/18. I'm thinking of getting a lowering spring like eibach pro kit or tein s-tech.
the question is, would i need to modify my fender if i lower my car so that i wont rub?
Honda Civic 10th gen Should i lower my vehicle or not? IMG_20200906_152505
Cejam4
Marco
Chicago
2020 Civic Si Sedan
18x9.5 +35
235/40/18
Lowered on D2 springs no rubbing
I would really look into fitment industries gallery and look for guys with your same setup and make sure they aren’t rubbing
Honda Civic 10th gen Should i lower my vehicle or not? 06ECC7D2-940C-45A5-A033-1F1B12D48AD2
Honda Civic 10th gen Should i lower my vehicle or not? F0F48E97-26CB-447C-BC9A-B1AE860DB4CF
GoldClass
Singapore
Civic Hatchback
I believe the oem tyre size is 215/50 R17. Now is 245/45 R18 which is 4.7% bigger. With et35 and 9.5” wide, it likely will rub at the fender tab if it lowered with pro kit when the suspension is compressed or go over a pot hole. But if your model is 2019 onwards, it may not rub b’cos there is no fender tab.
Nah. OEM Si tire is 235/40-18 just to let you know.
Autocube
Daniel James
Philippines
Honda Civic 1.8E
18x9.5 +35
235/40/18
D2 springs drops the vehicle by 2"+ right? And pro kit does .7" front and 1" rear?
don't you rub even with loaded passenger? Cuz i sometimes i have 4 passengers w/ me.
Autocube
Daniel James
Philippines
Honda Civic 1.8E
So fender rolling is needed?
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
I'm running 245/40 on 18x9.5 +35 lowered on Eibach prokit. I had to do fender tab mod. More sidewall will definitely rub
Autocube
Daniel James
Philippines
Honda Civic 1.8E
Got any picture that i could refer to? And i'm actually really new to this. What are the usual fender tab mod made to eliminate rubbing
