She ought to drive it at highway speeds for 20min, or further than 20mi, once a week.So my mom got her car back in December and only drives it five miles to work and back. No joke, she hasn't even traveled 3,000 miles.
I told her to keep the original oil in the car till she hits 15% or so, but should she consider otherwise in this case? Just curious. I think she's still at 60% or so.
I use PUP. Didn't notice a decrease in fuel economy. It could be you had some dilution and now there is relatively thicker oil. If that's the case, it is a good thing. Better for wear.I've done my first oil change after 7k miles or so using Pennzoil Platinum 0w-20, new filter as well. It SEEMS like my mpgs have gone down a tad. Is this normal?
Thanks.She ought to drive it at highway speeds for 20min, or further than 20mi, once a week.
The MM takes into account short interval drives and also how long the oil has been in. If it's the factory fill, I say keep it in there, and just go for some Sunday drives.
If the oil is changed early, if it were me, I'd add LiquiMoly to the oil. It's choked full of molybdenum, which is the predominate thing 'special' about factory fills.
If the oil stays in, and she doesn't modify her driving routine, sending some of the oil away for analysis when it is changed can be informative. If there is a high water content or acidity to the drained oil she should definitely do those Sunday drives. If the analysis comes back A-okay, not much of a need to change driving behavior.
Sorry about that.Thanks.
So I can't find a full synthetic 0w20 oil from them. If you're speaking additives only, I'm not sure which product among theirs would be appropriate.
Thanks, I found it!Sorry about that.
Yeah, it's an additive: the MOS2 anti-friction additive.
IIRC their special tec aa oil comes in 0w-20, but doesn't actually have that much MOS2 in it.
Molybdenum is really good for easing friction where there are irregularities on metal to metal contacts. Factory fills usually have a helping of molybdenum so the piston rings and cylinder bore experience a nice wear-in and can developer a good seal.
I would just add afterward. I think 1/2 to 3/4 for the volume of oil in the engine. Dealership may question you or not add it and make a fuss. Owners manual says the car doesn't need anything so it is technically not advised. Don't worry though- this will not harm the engine whatsoever. If she's got the 1.5L, it's good for the turbo too.Thanks, I found it!
So would I ask the service place to add this in with the oil change, or do you throw this into the oil refill part of the engine after they perform the oil change?
I wouldn't recommend additives to this engine as 0W20 oil is thin oil and additives can change the viscosity a little. Just go with good oil like Pennzoil or mobil or Amsoil but stay away from additives as fully synthetic oil is more than enoughI would just add afterward. I think 1/2 to 3/4 for the volume of oil in the engine. Dealership may question you or not add it and make a fuss. Owners manual says the car doesn't need anything so it is technically not advised. Don't worry though- this will not harm the engine whatsoever. If she's got the 1.5L, it's good for the turbo too.
Don't wear nice clothes when opening the bottle. .. It's got a pull-tabbed seal in the opening that takes some force to pull out, and contents hanging onto the seal may fly onto you. MOS2 is VERY dark, and very staining. Because it's dark, the next time the oil is drained, the tech may make a comment about how it was really dirty... Just the molybdenum; no need to worry.
But you know my mother's particular situation, right? Her oil has been in her car too long (eight months) taking only short trips, yet she hasn't even hit 50% on her factory oil with the molybdenum.I wouldn't recommend additives to this engine as 0W20 oil is thin oil and additives can change the viscosity a little. Just go with good oil like Pennzoil or mobil or Amsoil but stay away from additives as fully synthetic oil is more than enough
Seems you missed the context. The factory fill hasn't been in the car for many miles and the owner is considering changing it based on time, without the miles. Factory fills have higher molybdenum. My recommendation for an additive was to continue the specific benefit of the factory fill as the owner slowly accrues miles.I wouldn't recommend additives to this engine as 0W20 oil is thin oil and additives can change the viscosity a little. Just go with good oil like Pennzoil or mobil or Amsoil but stay away from additives as fully synthetic oil is more than enough
Concern over visocity w/r to MOS2 additive is moot- it's a non-issue. The prescribed dosing is 5% of the total oil volume in the car. The Mos2 is suspended in mineral oil. I personally use it every fill (unless I use a different additive). A sample size of 1 is worthless, so I won't claim safety or efficacy, but my point is that I've used the product multiple times. It flows. It's not gunky or chalky.But you know my mother's particular situation, right? Her oil has been in her car too long (eight months) taking only short trips, yet she hasn't even hit 50% on her factory oil with the molybdenum.
What's worse? Not letting the factory oil do its job because of a premature change (per the MM), or trying to continue the job after said premature change with an additive that might alter the viscosity?
