Shift Boot Swapping for CVT
n2da2nd
It's Senor Bane to ya
Nam
DFW
A little DIY Sunday funday CVT shift boot swap that took about an hour to finish.
1. First use a flat head or a trim removal tool to pry the "boomerang" handles. Be careful not to break 4 clips each side.
2. Locate the indicator marks on the side of the shifter collar. There are 2 clips right beneath the marks that you have to push them in before pulling the shift collar down. You then find the first screw to remove. Once it's out of the way, remove the cover above the first screw, to find the second one to remove. Once they both removed, the shift knob will slide right off.
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_200249
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_200306
Honda Civic 10th gen Shift Boot Swapping for CVT Photo_1592181270078
3. Remove 2 screws to separate the surrounding plastic base of the shifter. Unclip all the electrical connectors (econ, ebrake, and brake hold) by push in and lightly wiggle the connectors loose.
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_200340
4. Use the flat head again to push in 4 orange clips to remove the shift boot base. There will also be another electrical connector for the shifter illuminator lights that need to be unclip.
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_200440
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_200457
5. There are another 4 clips that need to be remove from the shift boot base to take out the leather shift boot. Afterwards, you will have to manually remove 8 heavy duty paper clips (6 on both sides and 2 on both ends.) Try to reuse them if you could on the new shift boot replacement.
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_170951
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_171002
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_173157
Honda Civic 10th gen Shift Boot Swapping for CVT IMG_20200614_195952
Honda Civic 10th gen Shift Boot Swapping for CVT 20200614_200523
6. Lastly, remove the zip tie that holds the collar ring. Replace it with another zip tie or a thin metal wire.
Honda Civic 10th gen Shift Boot Swapping for CVT Photo_1592181426667
7. Put everything back in a reversed order. Enjoy your new shift boot!
Honda Civic 10th gen Shift Boot Swapping for CVT PSX_20200614_204002
2018 Sport
Tim
NC
Awesome tear down! Just bought one of these my self. Definitely saved me some time
verzachaye
Zach
Hawai'i
2017 Honda Civic Hatchback Sport Touring CVT
awesome instructions man. related question- do you think swapping the manual shift boot with the cvt shift boot would fit? looking to give my interior a sleeker look.
n2da2nd
n2da2nd
Nam
DFW
So you want to use a manual shift boot for your CVT?
verzachaye
Zach
Hawai'i
yes. would look a bit more sleek imo. just would like to find out if it's compatible.
n2da2nd
n2da2nd
Nam
DFW
I think it should work. The shift boot I got is for a manual.
verzachaye
Zach
Hawai'i
JuiceStainD
Juice
Perkinsfield, ON
'18 LX Sedan
The staples are a pain in the ass. I ended up breaking them all off. I don’t see how you expect me to take them all off in one piece and replace them back all over again. It’s impossible without breaking them.
