Searching (positive) Battery Cable Assembly Starter
josemperezdiez
Puerto Rico
Honda Civic EX-T 2016
Hello I own a Honda Civic 2016 model Ex-t.
Some time ago I had to replace the positive battery terminal due to blueish sulphate salts build-up. Over the weekend my car did not start, took it to service and mechanic indicated that the problem had to do with the positive battery. Recommed me to buy the original parts, as it turns out it comes with the whole cable assembly. I am searching different sites to buy the parts but I have been unsuccessful. Can anyone knows what is the part number.
The part number I am looking for is tagged as “23”.
Honda Civic 10th gen Searching (positive) Battery Cable Assembly Starter CB236E6E-8872-4290-91C5-191F125D7771
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 SPT 17 EX-T 08 LX 21 CRV 12 Acc 14 328I CONV
Unfortunately that part will not work on your car, your battery cable is tapped into the transmission harness. the correct part number for the battery cable is 28150-5CG-A10
haltamer
Essex, UK
FK8 (UK / RHD!)
How bad is the corrosion? Any pictures?
Often you can clean it up with electrical contact cleaner and a small wire brush - Just remember to grease it when you reinstall!
