I still have the factory one on there for now. It's not pretty, but I've thought about using some solution to reapply it and remove the air bubbles.Has anyone applied/found a screen protector for the infotainment unit?
Partially habit, but I am also thinking about ordering one that will reduce fingerprints and glare. Also, I don't think the surface of this is as strong as most phones which use Gorilla glass. I assume it's plastic but I could be wrong. Plus most people will be keeping the car far longer than they keep their phone.I'm curious... are you wanting a screen protector out of habit, or because this is a known poor quality glass screen?
Well screen protectors help hide fingerprints a lot easier, which means less cleaning and less chances of scratching the unit while cleaning it. Also just for peace of mind if you were to scratch the Infotainment unit, you're stuck with that scratch for the life of the car not just 2 or 3 years when you're ready to get a new tablet or phone. Its just like people that want to put a clear bra on the car, you may never need it but the added peace of mind knowing you're adding an extra layer of protection from rocks and debris is worth the bra.I'm curious... are you wanting a screen protector out of habit, or because this is a known poor quality glass screen? I've been using android phones and tablets since the original "droid" in 2009 and have never used a screen protector (A case, yes, but not a screen protector). Scratching isn't really a problem unless you actually drop your phone face down on concrete, and even then, it's rare (in my experience at least - I've had several drops). I can't imagine anything that would happen inside of the car that would cause the need for a screen protector. Fingerprints haven't been a problem for me, and if they were - easy to wipe off.
Again, just curious, as the question surprised me in the first place.
Until today I had left the film from the factory on there and it was working fine. I would assume swapping out the film shouldn't change things too much. I still have the sensitivity set to low.As finicky as the touch screen is now, I wonder how another layer will affect the sensitivity.
Dealership took the thing off mine before it was delivered to meUntil today I had left the film from the factory on there and it was working fine. I would assume swapping out the film shouldn't change things too much. I still have the sensitivity set to low.
