S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play!
seselectronics
CivicX Basic Sponsor
Civic type R
The DRL+ FOG lights allow the FOG lights to turn on automatically when the DRL lights turn on without the necessity to switch on the headlights. The device has a switch and you can disable or tun the device off at any time, When the module DRL +FOG lights is on the rest of the functionality remains the same.
The installation is very simple and just require some basic knowledge in electronics. The installation is performed trough two T -Splice wire terminals. A fuse plugs and ground terminal attached by a screw located next to the main car fuse box. The installation time is around 30 minutes for a person without advanced knowledge in electronics.
Honda Civic 10th gen S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play! IMG_5810.JPG
Honda Civic 10th gen S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play! IMG_5819.JPG
Honda Civic 10th gen S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play! IMG_5820.JPG
bbeem
Ben
Iowa
Will this allow for fog lights on with high beams on?
seselectronics
seselectronics
Civic type R
@bbeem , Yes, all the functionality remain the same, you can turn on the high beam or low beam like default and work perfectly fine all together.
ManfromRI
RI
17' CW Civic Type R
So is this something that will be for sale or?????
seselectronics
seselectronics
Civic type R
Sorry guys I tested high beam + FOG and has a separate output, ( I didn't realize when you turn the high beams on the fog lights go off) but I need to add another input. The module can do it definitively .
seselectronics
seselectronics
Civic type R
DJayG3
DJ
Southern NH
2019 Civic Si Sedan
Is the install guide available for this product? I’d be interested in seeing what’s involved before buying...
Thanks
seselectronics
seselectronics
Civic type R
Thanks
The installation is very simple , just need to remove a fuse from the fuse box and plug a fuse connector , remove existing screw next to the fuse box and insert the fork terminal , and has two t tap wire terminals you need to install on 2 wires . (Example picture )
That’s basically the whole installation. Previously you need to remove that panel - cover to have access to the connectors.
Honda Civic 10th gen S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play! 73E4B219-AC3B-46FF-8EBD-707CDB6906A2
Honda Civic 10th gen S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play! BA47735E-BC32-4620-BF0C-F7B6DDE8BE25
Honda Civic 10th gen S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play! 80807815-3562-4CE2-96CE-236F5F7E61A2
Honda Civic 10th gen S.E.S module 500 series DRL + FOG lights ,DRL/FOG / HIGH beams lights module (Now side markers!) Plug and play! 3E463CD9-6B56-42B7-B5AE-7FFBF5BBA234
