Is that a catted downpipe??HahaMore details to come..........
So are you saying that a downpipe is pointless unless you upgrade the turbo?The restriction at this point is the turbo/turbine. Not the DP or exhaust. I've already tested PRL's 3" full catless DP at factory boost levels and it didn't make any power when actually using a proper before & after tune. Pending on a clutch to test high boost to see how much torque we can make with the DP, but anyone looking for "big" power gains will need a replacement turbo first as the exhaust is NOT the restriction. The turbine wheel and turbine exit is TINY and even the factory downpipe/exhaust is enormous in comparison.
both are useless unless you max out your car on a custom tune first.So are you saying that a downpipe is pointless unless you upgrade the turbo?
not really IMO, I somewhat understand what you are saying but you'd be better off making x amount of power from an upgraded turbo that's well within its range of efficiency than trying to completely max out the little stocker.both are useless unless you max out your car on a custom tune first.
I'm pretty sure I've maxed out the little baby stock turbo with just a tune and good fuel.not really IMO, I somewhat understand what you are saying but you'd be better off making x amount of power from an upgraded turbo that's well within its range of efficiency than trying to completely max out the little stocker.
Staying "Tuned"I'm pretty sure I've maxed out the little baby stock turbo with just a tune and good fuel.
if your really looking for a power monster, max out your tune first...THEN upgrade your turbo, see if you can extract more from that, Then maybe DP Then maybe IC. either way you'll be needing a new clutch.not really IMO, I somewhat understand what you are saying but you'd be better off making x amount of power from an upgraded turbo that's well within its range of efficiency than trying to completely max out the little stocker.
Not for CVT owners xDThe 10th gen Si having the same 1.5 engine might actually be a boon for the EXT if Honda decides to put a bigger turbo on the Si lol, assuming the flanges line up etc. Instant upgrade path for the EXt guys!
Well, depends how you look at it. It could just mean we might eventually see posts like "How much will a new cvt unit cost me", "cvt went boom ", "how well is your cvt holding up with the bigger turbo" or "cvt acting weird after turbo upgrade" lolNot for CVT owners xD
The one on the left is catted and OE lol.Is that a catted downpipe??Haha
I am excited to see what your car will do with a new clutch. At what power level did it start slipping and do you have a lead on a beefier replacement? We will do our own testing and hopefully our clutch holds out. Hoping to see some improvements in spool and transient response.The restriction at this point is the turbo/turbine. Not the DP or exhaust. I've already tested PRL's 3" full catless DP at factory boost levels and it didn't make any power when actually using a proper before & after tune. Pending on a clutch to test high boost to see how much torque we can make with the DP, but anyone looking for "big" power gains will need a replacement turbo first as the exhaust is NOT the restriction. The turbine wheel and turbine exit is TINY and even the factory downpipe/exhaust is enormous in comparison.
I haven't heard of Honda's CVTs having any major issues. The Civic is a mass produced and for every "tuner" there are 100s regular drivers. So the junk yards should be stocked with plenty of used CVT for cheap.Well, depends how you look at it. It could just mean we might eventually see posts like "How much will a new cvt unit cost me", "cvt went boom ", "how well is your cvt holding up with the bigger turbo" or "cvt acting weird after turbo upgrade" lol
First time it slipped was about 260wtq. Then it finally really let go around 280-290wtq. Each time it recovered -- to a point. But I can tell the slip events had wear & tear on the assembly and it's just not the same. HOlds reduced torque levels OK (around 250wtq seems to hold out).I am excited to see what your car will do with a new clutch. At what power level did it start slipping and do you have a lead on a beefier replacement? We will do our own testing and hopefully our clutch holds out. Hoping to see some improvements in spool and transient response.
@Hondata broke a CVT intentionally to find the limit if I'm not mistaken. KTuner has also had his personal CVT test car whine and scream, so we know where the limit is. They are not very strong and they are very expensive to replace if buying one from Honda. Tuning them should be done with care and with an "OK" from the owner to push it.I haven't heard of Honda's CVTs having any major issues. The Civic is a mass produced and for every "tuner" there are 100s regular drivers. So the junk yards should be stocked with plenty of used CVT for cheap.
