RV6 Catted Downpipe/Front pipe now available!
RV6
RV6
IL
rv6-p.com
2020 CTR, 2023 Civic Si
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
2021 Acura TLX Type-S / 2018 Civic Si Coupe
These look very nice.. and price difference for us that already have the 3" front pipe?:hmm:
RV6
RV6
IL
rv6-p.com
Awesome. Any data available on the power boost from this?
Haven't had a chance to dyno yet. We are expecting a few HP less than the catless version.
Shoot us a email and we can work something out.
L15B7
Los Angeles, CA
2016 Honda Civic Turbo
I know that the bottom heat shield won’t fit, is that a cause of concern for us????
Should we order your ceramic version?
In other words, by not having a lower heat shield are we prone to any damage?
Thanks RV6
RV6
RV6
IL
rv6-p.com
Thanks RV6
Not really a concern. The lower heat shield only covers half of the converter anyways. The upper heat shield is more important since the intake path passes directly over it. Nothing will be damaged from not running the heat shield.
Ceramic coating does a excellent job at keeping the radiant heat down in your engine bay. It is not required since our parts are made of stainless and will not rust.
Mogadee
'07 Mazdaspeed 3, '17 WOP Si Sedan
@RV6
What is the benefit of getting the front pipe in addition to the downpipe with the stock Si exhaust?
RV6
RV6
IL
rv6-p.com
@RV6
To be honest there really isn't much of a advantage of getting the front pipe with the stock exhaust due to bottle necking. However our front pipe will bolt up to the stock exhaust and allow for future upgrades to a larger exhaust. It is also cheaper to buy the frontpipe/downpipe together opposed to separately.
L15B7
Los Angeles, CA
Do you still have any catted downpipes available?
I’m going to order one next week.
CyberCT
Nazareth PA
2018 Civic SI Coupe
Would the material used and welds be able to withstand the high temps if I had one sent to Swaintech to get coated? Got this done with my RSX's Comptech shorty header and it significantly reduced engine bay temperatures.
Also, what gains are expected from an SI without any ECU tunes (stock)?
RV6
RV6
IL
rv6-p.com
Yes, we currently have them in stock ready to go.
We offer ceramic coating however you are welcome to send the part out to be coated on your own. The part should be able to withstand any coatings.
I would expect around 7-10WHP and 7-10WTQ on a stock tune running 87.
WOPSiWOT
South Carolina
2017 Civic Si Sedan
IDriveanSi
Gerry
Los Angeles, California
2018 civic si
Any info on what brand and model number cat was used for the rv6 catted. Trying to determine if I should go catted or catless.
RV6
RV6
IL
rv6-p.com
The cat is a custom made part. It is 300CPSI and made of high temperature Feceralloy foil. Much more robust than anything available off the shelf.
