Hell yeah, cant wait!!!We will be starting to take preorders for the catted version of the DP and DP/FP soon.
Great question... how many miles without a defouler would be a better questionHell yeah, cant wait!!!
btw, how many miles have you put on the catted downpipe? any cel yet?
About 900 miles with no CEL. The catted version will use a short defouler.Great question... how many miles without a defouler would be a better question
Wait...?!!! What So the bottom one wont fit?? you should have room to put it on... This might be a deal breaker if you can't affix the lower heat shield @RV6Only the top heat shield.
Please make these brackets... since I'm sure 95% of the people that are going to buy this are going to want the lower heat shield as wellLooking into the lower heat shield. Definetly going to require us to get some custom brackets made.
After some careful measurements there isn't enough room for the lower heat shield bracket. We would have to drill into the converter body. We might tweak the casting to make it work in the future.Wait...?!!! What So the bottom one wont fit?? you should have room to put it on... This might be a deal breaker if you can't affix the lower heat shield @RV6
You will have to use our front pipe if you want a full 3" system. There simply isn't enough room for a proper seal using the factory flange and a true 3" system.Is there an option with the other end being 3 inches also to fit my after market fp from a different company?
Any super cool sound clips of the catted DP available?After some careful measurements there isn't enough room for the lower heat shield bracket. We would have to drill into the converter body. We might tweak the casting to make it work in the future.
Will the full 3" DP/FP work with the rest of the factory exhaust?Looking into the lower heat shield. Definetly going to require us to get some custom brackets made.
Front pipe is full 3" the downpipe alone starts at 3" reduces down to 2.5" to work with the factory front pipe. The reducer section unbolts at vband anytime can can be used as a full 3" downpipe/front pipe combo.
I haven't had a chance to make sound clips. However it close to stock.Any super cool sound clips of the catted DP available?
Yes the front pipe will bolt up to the stock or any aftermarket exhaust.Will the full 3" DP/FP work with the rest of the factory exhaust?
How's the exhaust process going almost complete?I haven't had a chance to make sound clips. However it close to stock.
We have the mid pipe done. Just gotta get all the trims figured out. I think there are 7 variations of the exhaust.How's the exhaust process going almost complete?
damn that's going to be crazy! lol can't wait to hear a soundclip of loud to loudestWe have the mid pipe done. Just gotta get all the trims figured out. I think there are 7 variations of the exhaust.
