Rotors for Genesis brembos
Fc3_Si
Rdel
Las Vegas, Nevada
2007 Honda Civic Si Coupe and 2017 Honda Civic Si Coupe
Hello,
I currently have Genesis brembos and Nissan Rogue w/3rd row sitting. I wanted to upgrade my rotors so I bought a set from R1 concept website, but when I test fit the rotors, it wouldn’t fit. I made sure I picked the right car year and model. However, it did give me two option:
Option 1: Nissan Rogue “ excluding Hybrid, select and sports” (options: S, Sl, Sv, 3rd row seating
option 2: Nissan Rogue select (option: S)
the rotors I have is option 1, but it doesn’t fit. So maybe it’s option 2 and has anyone with Genesis brembo experience similar problem?
Thank you
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
Here are the part numbers that came with my kit from slickfab for the genesis brembo conversion:
E-Line:
https://www.heeltoeauto.com/big-bra...per-conversion-613-67104l-r1c.613-67104l.html
https://www.heeltoeauto.com/big-bra...per-conversion-613-67104r-r1c.613-67104r.html
I also see they make them in their geomet coating:
https://www.heeltoeauto.com/big-bra...per-conversion-810-67104l-r1c.810-67104l.html
https://www.heeltoeauto.com/big-bra...per-conversion-810-67104r-r1c.810-67104r.html
And finally, here's the page with all rotor options included:
https://www.heeltoeauto.com/brake-c...bk-hyundai-genesis-brembo-caliper-conversion/
For the actual year, I'm not entirely sure. Scouring the forums only told me that any rouge 3rd seater rotors should fit, but since you tried that already, apparently thats not the case.
Fc3_Si
Fc3_Si
Rdel
Las Vegas, Nevada
  • #5
E-Line:
Thanks man. This helped me a lot. R1 concept sent me the replacement.
White - Out
U.S.A
Ford Pinto
So im in the process of replacing my calipers on my 8th gen SI.
Ive read a couple threads here since i havent seen anyone do a 8th gen swap.
Im assuming they will fit.👇🏻
http://slickfabllc-com.3dcartstores.com/Brembo-Big-Brake-Upgrades_p_28.html
I noticed that if you get these rotors you will have about a 1/16 overhang on the pad.
Im just wondering if you guys have ran into any inconveniences with that overhang.
Like brake shudder or such.
Also, would this swap be a superior option over the dc5r calipers with S2000 rotors?
Thanks!
jayy_swish
Jay
Thanks!
I just sand down the left over pad from the overhang and no problem
