Yes I have the 27Won race RMM on my CVT. Most of your trouble will come from trying to drive normally from a stop. Medium load with low rpm is a recipe for the shakiest shakes you can imagine. It will shake the mirrors so bad you can't see out of them. But if you put it in sport and give it enough gas to get the revs up above 3k, the vibration evens out. If I was you, I'd buy their new street version. It's cast so it's cheaper, the poly is softer so less vibration, and I imagine it'll be the right mixHi has anyone installed an aftermarket RMM On Cvt? If so how bad are the vibration and what has improve?
I’ve been looking through other threads and a lot of people recommend using the OEM RMM from either an Si or Type-R. You get some of the performance gains of an aftermarket RMM with little to no NVH. I’ll probably be going that route myself.Hi has anyone installed an aftermarket RMM On Cvt? If so how bad are the vibration and what has improve?
I just installed the SI rmm and it works great. No NVH and most of the wheel hop and instability is gone. Also recommend the SI rear sway bar. If you like taking the corners hard a strut bar comes in handy.I’ve been looking through other threads and a lot of people recommend using the OEM RMM from either an Si or Type-R. You get some of the performance gains of an aftermarket RMM with little to no NVH. I’ll probably be going that route myself.
That’s great! Just ordered a Type-R RMM forO
JEALOUS! I could not find the Type R mount in stock so went with the SI. Please share your impressions once installed.That’s great! Just ordered a Type-R RMM for
myself, will def look into sway bars and strut bars too.
I lucked out and happened upon it on EBay. Will definitely give an update after I install it.JEALOUS! I could not find the Type R mount in stock so went with the SI. Please share your impressions once installed.
Yep, them Type R RMM seem to have disappeared. You will likely not see a difference until you add horses like with a CAI + Intercooler + 93 octane or Increase boost by even +3 psi. Do booth and an upgraded RMM is vital.I bought one of those type r RMM's on ebay for 50$. It's been on for a few months now. Install was cake, but I really couldn't tell much of a difference. I'll be adding the perin inserts on my next oil change.
Edit: well dang, when I bought mine there were 6-7 of them. Now I can't find any.
