Review of the ETL CVT Cooler
CVT4NYC
Will
NYC
‘21 hatchback sport
Hello Everyone!!!
I have a 2017 Honda Civic Hatchback (CVT)
Mod List so far:
Greddy DD exhaust non resonated
PRL cobra CAI
ETL cooler
(waiting for my sirimoto flex fuel kit, on backorder with no estimated ship date)
Removed weight, took out back seats, carpeting back there, and spare tire
I recently got the CVT trans cooler by ETL performance.
Link: https://etlperformanceproducts.com/products/transmission-oil-cooler-kit-honda-civic-cvt
First things first, this is a BITCH to install, mainly the part that links directly to the cvt filter.
It took me 3ish hours to get it right without leaks. For the performance overall, I notice a decrease in temps. I haven't done pulls with it yet, but that's because I'm waiting for more HCF-2 fluid since it drained me 4 times when I powered on the ignition, drained all of that cvt fluid, luckily only had a few quarts in there, then just added 1 just to make sure it wasn't leaking. I had to adjust it 3 times. The reason it's a pain is because, the engine bay is already cramped especially in that area.
After finally getting it so there's no leaks, I went out on a drive for around 1 hour on the highway, sometimes my temp got at around 215-225 during spirited driving. With this I didn't even cross the 200 mark.
One bit of advice, when installing this, don't use the method they show which is mounting it in the wheel well if you have the PRL CAI. I couldn't fit it there, so I mounted it in front of the radiator, right on that black bar when you take the bumper cover off. I ran the hoses through, over the CAI and through that little opening to the cooler. I will post an update on this once I fill her back up to the 3.9 quarts that are required so I can do a few big pulls and report my temps here. But so far a very very noticeable difference which can help prolong your transmission's life!
Future plans: waiting for sirimoto flex fuel kit
some NRG 800 series seats
MAP DP and FP
W1 Turbo
Custom tune
Great write up man. I actually just ordered this earlier today. ETL’s website has a unadvertised 4th of July sale and I ended up getting it for $183 shipped. Where exactly were you getting the leak?
galarianash
United States
2017 Honda Civic Sport Hatchback
The leak wasn’t necessarily a “leak.” i had to torque the part down that attaches to the metal plate a lot. took several tried and i had to hollow out the top right hole on the pump with a drill bit because one of the bolts wouldn’t fit through it
SDAlexander8
Steve
Indianapolis, IN
2017 Civic Si Coupe
For anyone wondering, it still can be mounted with the PRL CAI. Just gotta have a few spare parts on hand.
e40 custom tune from IMW (27PSI)
RV6 r365 turbo
PRL turbo inlet
Race MAF
Skunk 2 intake manifold
Mishimoto FMIC full kit
3" catless downpipe
3" front pipe.
Forge BPV
Oil cooler
Etc
This cooler is a massive improvement, keeping my transmission temps reasonable even under extreme driving conditions. The cooler provided could be better, but that can be easily changed for something larger and more effective.
I dont mean to be the bearer of bad news, but your condenser is leaking.
chmst
Mikey
philadelphia
2017 honda civic EX-L
I learned something new today 😂 (not trolling, I really had no idea what that spot was, I just assumed I somehow got oil/grease on it)
My a/c has not worked since ~5k total miles and I haven't bothered to even take it in under warranty/look into it.
Thanks!
SDAlexander8
Steve
Indianapolis, IN
2017 Civic Si Coupe
Thanks!
I can’t say for certain, but they may deny warranty coverage on that because it looks like somethings may have struck it and damaged it. Hard to tell. The pic isnt close up, but that is a lot of bent fins around the greasy area.
Zacaea
Zach
Wichita, Kansas
2021 Civic fk7
I’d like to know a bit more
1. How much fluid would need to be added to make up for the extra cooling
2. I have the lane departure and LKAS soI’d have to find a mounting spot in front of the radiator. Are there holes I could mount to?
Civii
Los Angeles / Antelope Valley
2017 Honda Civic
A few ounces extra. Also, I mounted mine to the black bar above the crash bar and radiator. I used one of the holes that is typically used by a clip for the engine cover above the radiator. and the second location for the bracket was janky, I just jammed it below my crash bar and intercooler (PRL). It doesn't move the intercooler and the right angle bracket goes between there. It's pretty secure and doesn't move. Keeps the radiator in the center of the grill. Big difference in temps.
