Dave B
- Dave
- Oct 19, 2019
- 60
- 767
- 468
- Whitby On Canada
- Corvette Z06 (sold) 2020 CW
[/QUOTE]
I would have thought the MK806 would be much easier to use than an AP200 and easier to use with different vehicles. Also not a problem if you change phones although it is more expensive.
On a different topic, when the electronic parking brake actuator retracts, I assume you still have to push in the hydraulic piston by some other means. Correct?
Good to know this tool works on a 2018. I would hope this function isn't any different on a 2020.I was able to retract my brakes with an Autel MK806 Pro.
Once the brakes are retracted (you can hear the motor) you can shutoff the car and work on the brakes. The e-brake motors do not buzz, meaning they are staying in the retracted position.
When everything is assembled, switch to key on engine off then back to the scanner to get out of service mode. The e-brake motors will buzz back to the normal position.
The ABS and other warning lights will shut off.
