REQUEST: Block Heater Install
sniper
Toronto, ON, Canada
2016 Civic Coupe Touring
Anyone know how to easily access the radiator drain plug and engine block bolt so I can install the block heater?
sniper
sniper
Toronto, ON, Canada
I do, it says to drain using the radiator drain plug, then remove the engine block bolt and install the heater there. It looked easy until I tried to fit my hand/tools in there :(
ChrisSi
Wisconsin
2018 Civic Si sedan, 2009 Pilot
You might have to pull the intake to work on this.
HondaDNA
Akron, OH
97 Hx, 17 Sport
Its much easier to install from below. I used a deep 19mm socket with a 1in extension to put the ratchet in a spot that I could turn it. I didn't drain the coolant in mine, only lost about half a quart.
ChrisSi
Wisconsin
I suppose you don't have photos of that angle? I'm definitely installing this on mine this spring.
HondaDNA
Akron, OH
97 Hx, 17 Sport
I do not. I used a lift so doing it from below was no problem. If you go from above you're best to remove the turbo intake tube.
augustus
ohio
2017 Hatch EX Lunar Silver
so was it pretty messy? I'm assuming you just get the heater in there as fast as possible, fighting a downpour of coolant? I'd rather not drain, but I don't have a lift, and whatever comes out is likely going to be on me!
sniper
sniper
Toronto, ON, Canada
Went to my buddy's shop, although we just did it on the floor, without removing bumper.
  1. Remove intake hose
  2. Break bolt from above
  3. Install heater element
  4. Run wire, drop it, tie to bumper.
Yes, it is messy, but loose less than 1gl of coolant.
chestypuller
Skip
alaska
None
anyone know the blockheater thread size? is it 28mm im looking at the zero start block heaters and dont know he part number for a 1.5 turbo civic
chestypuller
Skip
alaska
None
getting ready to install this motha soon! probably do a oil change while im in there too. getting in the 40f rang at night.
chestypuller
Skip
alaska
None
well got it all done, man that blue coolant is cool.
