REQ: Where The Hell Is The Headlight Fuse??!!??
Ketsto
Sweden
Prev./Curr. 2018 Honda Civic 1.0l. Soon 2020 Civic 1.5l Exec.
My manual says the high beam fuse is 29 and 30 in the Engine Fusebox.
I have tested every single fuse, and they are all constantly 12v.
I checked the driver side fuse box. Some fuses are switched, but not with the high beams.
The testing procedure:
Attach multimeter probe to ground, probe fuses. If they show 0v, flash the high beams. All either stayed constant or stayed off.
One of the high beam fuses was off, normally. It didn't turn off when I flashed, but it did when I turned the ignition and the entire lamp housing turned on, sans high beam.
What am I missing?? I want to tap into a high beam (switched with HB) power source for my LED ramp, but I really don't want to cut any factory wires.
calonzo
New Haven, CT
2016 Honda Civic Touring, 2007 Honda Civic Hybrid
It means that the fuse is not switched. The switch must come after the fuse.
Ketsto
Sweden
  • #3
So what does that mean? I have no choice but to tap the green wire that goes into the bulb connector? I have shrink tube solder connectors, is the really skinny wire strong enough to be able to be cut and stripped without being destroyed? I REALLY don't want to mess this up, y'know?
calonzo
New Haven, CT
I haven't tried it. But if you strip the wire far enough from the connector then you can always repair it.
arpypat
Arpan
Kansas City
2019 Civic Si Sedan ABM
You could also make your own harness to plug between the high beam bulb and the OEM harness connector. And just splice at that new harness.
calonzo
New Haven, CT
Where do you get the connectors? Do you have to go through Honda? That seems expensive. Do online auto part stores carry them?
arpypat
Arpan
Kansas City
Idk if you have the LED style headlights, but the halogen housing ones use generic off-the-shelf connectors.
Ketsto
Sweden
  • #8
So, piggyback harnesses exist. I didn't know that. I ordered one for the halogen headlights that matches the high beam bulb (HB3 plug), however I don't know how it is with the LED lights. I hope it's the same.
Apologies for the frustration.
