syndragore
@gray.fk7
- Aug 20, 2018
- 3
- 27
- 23
- California
- 2018 Civic Hatchback ST
- Vehicle Showcase
Looking forward to seeing your results!
I ended up going the same route but I used the VPSTX12 which is the shallow version. I am pretty happy with the results but now I just need to upgrade the door speakers.The setup bolts into the spare with it in it's original place. I lined the entire spare area with sound damping material to enhance performance. I retained 100% of the hatch cargo area.
Hey Vblue,With all due respect if he went after the amp which is the only way to do such without the proper interface then it’s still using the shitty signal as a source from Honda. Metra Axxess has the proper interface and I have a demo thread here. But what’s done is done I guess. I’m sure it sounds better then before but for me using the source signal after the amp wouldn’t have worked for my ears.
https://www.civicx.com/forum/thread...-speaker-audio-of-sport-touring-type-r.52248/
Well clearly you’ve never heard a properly tuned system in a car then. I have this installed and the sound quality is night and day from before with everything Honda does in the amp to destroy the sound.Hey Vblue,
I read the thread over you attached. This is probably one of the first options I've seen that actually use the spdif connection off the head unit and I'm really curious to see where that goes mainly because of the integration with voice commands/ Android auto. The source is pure but especially with that fix 82 trying to predict the clean source I'm curious what the difference in quality is that end of the day gets transferred over the speakers. Yeah theoretically it's cleaner but until we introduce an aggressively sensitive system into a background noise free environment i don't know how much you'll notice day to day.
So the non-shallow version that you have (VPSTX12) fits on the spare and the hatch floor still lays flat on it like nothing's in there?The setup bolts into the spare with it in it's original place. I lined the entire spare area with sound damping material to enhance performance. I retained 100% of the hatch cargo area.
Alright... didn't know you wanted to go that way with this. I've been doing high fidelity for a while and am newer to the car side of this, but you know how Fix82 works right? The whole purpose is to resumarize the signal and predict what ends were amplified and then remove that amplification to try to generate the predicted base clean frequency the head unit started with. Obviously that's not a perfect fix, but going into this I'd never heard of the processor you're mentioning and the overall community hadn't talked about it. On top of that the people that tapped off of the optical out I heard did have issues with getting their voice commands to work because it's a different set of wires so I'm really curious how you were able to fix that or what your solution was.Well clearly you’ve never heard a properly tuned system in a car then. I have this installed and the sound quality is night and day from before with everything Honda does in the amp to destroy the sound.
No it's the shallow version, but the floor is flat. Near the dsp it's slightly elevated but it's not noticeable unless you're looking for it.So the non-shallow version that you have (VPSTX12) fits on the spare and the hatch floor still lays flat on it like nothing's in there?
Finishing that earlier thought: sound quality is a battle between what you'll notice and what it's worth. I wanted to have an educated conversation about whether you think it's truly going to be noticeable in a middle grade quality car setup in actual day to day use. OR if you think while theoretically yes this will make a difference unless you're looking for it a predicted digital output will perform similarly to a true digital source in a typical driving environment.Alright... didn't know you wanted to go that way with this. I've been doing high fidelity for a while and am newer to the car side of this, but you know how Fix82 works right? The whole purpose is to resumarize the signal and predict what ends were amplified and then remove that amplification to try to generate the predicted base clean frequency the head unit started with. Obviously that's not a perfect fix, but going into this I'd never heard of the processor you're mentioning and the overall community hadn't talked about it. On top of that the people that tapped off of the optical out I heard did have issues with getting their voice commands to work because it's a different set of wires so I'm really curious how you were able to fix that or what your solution was.
On top of all this, this is sound. Every seasoned veteran when it comes to sound quality understands it's a battle of diminishing returns and
No issue with voice commands. CarPlay and the onboard voice command works as it should.Alright... didn't know you wanted to go that way with this. I've been doing high fidelity for a while and am newer to the car side of this, but you know how Fix82 works right? The whole purpose is to resumarize the signal and predict what ends were amplified and then remove that amplification to try to generate the predicted base clean frequency the head unit started with. Obviously that's not a perfect fix, but going into this I'd never heard of the processor you're mentioning and the overall community hadn't talked about it. On top of that the people that tapped off of the optical out I heard did have issues with getting their voice commands to work because it's a different set of wires so I'm really curious how you were able to fix that or what your solution was.
