Replacing 2019 CTR front vent garnish assembly with 2020/21 version?
FK8CW2019
Lee
Saigon
Civic Type R
So, the rear garnishes can be installed without removing the rear bumper?
you will have to remove bumper for sure. Need to do a cut out for the new garnish to fit. People rumored that late 2019 had precut but it is not true.
oak
wayne
so bay, los angeles
civic type r
Someone asked about the rears. I just did this mod a couple weeks ago, I initially tried the fk7 garnish close but no cigar. 😂 the rear bumper needs to be removed to access the mounting screws for the side garnish. Simple bumper removal
Honda Civic 10th gen Replacing 2019 CTR front vent garnish assembly with 2020/21 version? 2A4F93C8-0AB2-403F-8E4D-BCFA3C4CDDE4
Honda Civic 10th gen Replacing 2019 CTR front vent garnish assembly with 2020/21 version? 4BA7A47F-FC41-48C5-86F3-48FF34DD1E4D
FiveFingerCNTpunch
Lori
Pittsburgh PA
2019 FK8 type R - 2020 civic si
Where did you get the parts for it ? I want to swap the vents on my 2019 ctr
oak
wayne
so bay, los angeles
civic type r
I ordered mine through Honda corporate in Torrance. My parts guy mentioned they were coming from Irving Texas. I’m sure you can source them from any respected dealership in your area.
FiveFingerCNTpunch
Lori
Pittsburgh PA
A
Awesome. So did u have to cut anything or was it an even swap on your ctr ?
oak
wayne
so bay, los angeles
civic type r
See pic above for cut out reference. You’ll need to cut out behind the fake vents. These vents are actually functional and are vented behind the screen to relieve high pressure and clean up the side air curtain at higher speeds.
vtecr
FK
Eire
FK7 GT-Spec Daily, EP3 Type-R, EP1 Project, EU7 Beater (+ others I care less about...)
Looks great!
I was under the impression the FK7 and FK8 rears were the same. Can you explain more about what's different?
oak
wayne
so bay, los angeles
civic type r
At first glance they appear the same, but they are not interchangeable, over all contours and dimensions are different. Contrary to what people have said or you have heard. I purchased both fk7 and fk8 versions and have attempted to installed both sets they are not exchangeable. Hope this helps.
hikaru
Shawn
Marietta
The grills are visually different too.
FK7 - Hexagon
FK8- Rhombus
Honda Civic 10th gen Replacing 2019 CTR front vent garnish assembly with 2020/21 version? 3C1E6F1D-936A-4E99-A331-DC9290A3E705
  • Like
Reactions: oak
_silvy
Chicagoland
2019 Civic Type R
FK7 - Hexagon
FK8- Rhombus
Perfect picture to show the overall difference too. The Type R garnish on the outer bottom tapers than the FK7, which is mostly straight up and down
