In the US, the 12-volt battery is covered for 3 years or 36,000 miles.Is battery covered in the warranty? Extended warranty?
Thanks. I am hoping that the extended warranty covers the battery. BTW. Where did you get this information? I tried Honda Canada site but did not find the information.In the US, the 12-volt battery is covered for 3 years or 36,000m miles.
In Canada, the 12-volt battery is covered for 3 years with no distance limit.
The extended warranty (Honda Care in the US or Honda Plus in Canada) does not cover the 12-volt battery.
Re-read my post. Honda's extended warranty does not cover the 12-volt battery.Thanks. I am hoping that the extended warranty covers the battery. BTW. Where did you get this information? I tried Honda Canada site but did not find the information.
Are our batteries AGM, gel or wet-cell?
I'd still take Flooded over AGM personally 9 times out of 10 for a car... for cost/performance/longevity... so long as I was using it for it's automotive starting purpose primarily. The reserve capacity if you *really * need some juice on AGMs is usually a lot lower because it holds a much smaller volume of electrolyte... though it does come back better from deep cycles than flooded. If you let it sit on the charge and it pops it's reliefs and you lose some gas/electrolyte... you've lost what limited capacity you had and there's no way to replenish because it's sealed... using the O2 recombination cycle to keep going. Flooded just gas out when charging... making top offs with DI a possible necessity.Thanks again, Zroger73.
When the time comes, is there a problem to use AGM as a replacement? AGM is supposed to be superior to operate in areas with vast variances in temperatures between seasons.
The water pump is covered by the standard, 5 year, 100,000 km powertrain warranty and is also covered by the Honda Plus extended warranty.Zroger73:
I checked the link https://www.honda.ca/owners/warranty/standard-warranty and I am clear on the battery.
I am interested in what extended warranty covers. Is there a site for this? For instance, I want to see if water pump is covered in the extended warranty.
According to this site https://www.honda.ca/owners/warranty/honda-plus/extended-warranty, electrical is covered by the extended warranty? Infotainment is part of electrical, right?Interestingly, the Canadian Honda Plus warranty does not cover the audio system or any LCD displays (such as the instrument cluster or display audio screen), satellite radio, or inputs jacks. It also doesn't cover mechanical components of the moonroof and LED lighting is only covered for 1 year or 20,000 km in Canada (that must suck for 9th gen Accord owners with LED DRL failures!) The US Honda Care warranty covers all this.
Makes sense. No point to change the battery if it is still going strong.I tested the battery with the load tester over the weekend, and it's still strong... I'm going to test again before she leaves in August, and if it's marginal, I'll replace it. Otherwise, she'll be back home every few months to visit, so I'll test then as well. Worst case, she does have Honda's roadside assistance.
