BBTypeR
- Sep 24, 2021
- 3
- 58
- 25
- Illinois
- Civic Type R
I've been talking with XDI about their recommended ID F750 inline fuel filter. Adding it between the hard line and PRL flex fuel sensor.The new JSR intank setup does this
It basically removes all the restrictions from the basket (fuel regulator, oem fuel filter, tiny lines) and replaces it with a 535lph modified pump that hangs by itself....incorporates an inline 1000hp fuel lab regulator and stainless fuel lab filter that's serviceable. Add in the -6 AN fuel line that uses the stock line as a return and now you have amazing flow, consistent fuel pressure and no chance of having the oem fuel filter sending garbage to your expensive hpfp and injectors or losing a motor. Track guys could easily incorporate a surge tank if they wanted to as well but 99% of guys would be fine with the kit as it comes.
I'm on the dw300c right now - great pump - but unfortunately i refuse to risk another set of injectors/pump/motor with the oem fuel filter so I'll be upgrading asap
Fuel is really our biggest jssue and when you look at the basket and how small the holes/ lines are - the JSR upgrade becomes a must really - especially if you are on E which breaks down the paper/glue in the oem fuel filter.
So you can either keep replacing the oem basket ($125 + pita install) or spring for the upgrade and get peace of mind and alot more headroom for safe power. I've been bugging them for this as I know there are alot of us in the same boat. You can do a more fancy setup and spend more as others have but I think the target price was $1500ish which includes the pump, reg, line, relay etc is dirt cheap for what you get.
Hopefully they can keep the cost low as this is more of a safety mod first and performance upgrade second.
Would that catch the degrading filter and glue?
