NonyaBisness
- Dec 5, 2019
- 13
- 290
- 188
- United States
- 2016 Civic EX-T
OK, so I finally finished wiring everything up and got the sub playing today, shut the car down, got cleaned up and headed off in my other car, when I got home I noticed the LED's of my amp where still on, for whatever reason the LC2i Pro didn't shutdown after I turned the car off, so I switched the turn on sensing over to GTO instead of Audio and that seams to be working but it takes like a full minute to shut off after turning the car off and with how weak the batteries in these cars are I kinda wouldn't mine having an actual remote wire to fall back on.
I did things a little different, instead of burying the LC2i in the dash I ran the speaker wire taps from behind the headunit back to the trunk so I could mount the LC2i in the back (for easy adjustments and tuning) and so I ran the speaker wire down the passenger side (since the power wire went down the drivers side) and in doing so I noticed what was labeled like HD Radio Module or something behind the trim panel that the passenger side rear seat seatbelt rides against and was wondering if any of those wires might be a suitable tap point for a remote wire (anyone have a wiring diagram for that guy??), as that is super easy to get to without having to run a wire all the way from the dash back to the equipment.
Here are some photos, I still gotta clean up the wiring a bit and bust out my SMD DD-1 so I can do the tuning, it started to rain right as I was finishing up the install so I didn't get to do anything more then set the levels high enough to produce some sound from the sub to confirm everything was working, didn't even get to get pictures till after dark.
Side note, those of you with LC2i Pro's (if any of you have the Pro version) what are your settings for the Accubass Level and Threshold?
