REDRAGN
- Matthew
- Aug 9, 2021
- 15
- 618
- 1,475
- Cumming, GA
- 2019 CTR
Just picked up a new to me 2019 CTR for track use. For some context, I formerly raced NASA Honda Challenge HC4 and have participated in multiple HPDE events at tracks across the Southeast.
I'll be attending a single day event at Atlanta Motorsports Park in Dawsonville, GA on Sunday 29 AUG. This is a fairly technical track with 16 turns and lots of elevation change. Temps are currently projected at an 82 degree high with possible rain.
After lots of research on civicx, here is my prep for this event.
Factory suspension with front strut guide pins pulled and set to max negative camber
Motegi Track Light 18x9.5 with new 275/35/18 Nitto NT05 tires
Pro Car Studio Pro Design Mesh Syle Grill installed
Factory brake rotors and new pads with Motul RBF 600 fluid
Motul 8100 0w20 oil and OEM filter
New NGK OEM spec Iridium spark plugs
K&N drop in air filter
Fresh Honda MTF
Full clear bra
ZL1 Addons F&R rock guards
I'll get an alignment on Friday and have toe set at zero front and rear unless there is an alternate setting that works better for learning the CTR limits.
I think air pressures cold will depend on track and outside temps but I'll likely start around 34/35psi and adjust from there based on tire wear, handling, and hot temps
Depending on temps I'll cut on the heater to help combat hot coolant if necessary...if I get lucky with a high of 82 degrees the car might do ok heat wise. However, there is not an abundance of long cooling straightaways at AMP so we will see.
Y'all feel free to give me your thoughts and feedback...please keep in mind, most of these are not full on performance parts. I have freshened up all the fluids and wear items needed for safety & minimum required specs to deal with track temps. In the interest of learning the CTR strengths and weaknesses I wanted to put it on the track before I dive into performance upgrades.
Fresh Honda MTF
Full clear bra
