Jpierro79
- John
- Mar 6, 2019
- 33
- 398
- 273
- Myrtle beach South Carolina
- 2018 type R 2015 c300
I’ve been hearing crazy hp numbers from people saying red star is the best.
His 1/4 mile mph speeds are considerably lower that rated hp at the wheel output. Starters we’ve seen stock turbo 370whp cars do 117mph. That’s pretty on par especially using the Rob robinette calculator I’ve used forever. It’s spot on with type r calculating weight to hit 117mph. If you add vehicle weight and hp at wheels or crank it will give you an est et and mph. I’ve always had the mph be 99 percent accurate. Per exapmle I had a mk7 gti tuned on Apr stage 2 gti rated at 308whp and I ran a 12.454 at 111.3moh. The rob robinette calculator comes up with 111mph and car weighed in at low 3300s. A golf r stage 2 will hit 114-115 on stage 2 apr tune now we use crank hp to curb weight it calculates 114 mph. Now a 2019 mustang gt stock does 118 mph. The calculator comes in at 118. I know a late model mustang gt does 420whp on a dynojet.
now let’s go higher hp. A hell cat has 707 crank hp. Using the 4450 curb weight and 707 crank horse power. The calculator comes in at 126.7. The actual mph is 127-128mph In a 1/4 mile. Now let’s go even higher up a new mustang gt500.
4225 lbs and 760 hp at the crank and the calculator come up with 132.057 and real world is 132 mph.
Before you say it’s downforce the type r only generate 66lbs. To go from 145 to 132 would require 1000lbs of downforce or higher.
So if this calculator works between low and high hp cars with proven hp ratings either at the wheel or crank what’s happening to red star tunes?
Think about it. How can Red star motoring be losing so much mph. Do not say cause the type r is a track car cause the only reason in stock form it sucks in 1/4 is a 30 series tire on a 20 with no sidewall. It will still go the sane mph regardless of et if you stay in it. Even in roll racing real hp can be seen. A true 400whp type r outruns a c7 on Highway. Also it’s longer wheel base lends it self to traction for acceleration evennwith fwd. it’s got far better traction than a gti. A 650whp civic type r should be doing 145mph not 132. That’s a non gutted curb weight car. The mph is clearly off. After all a red star car that just made over 450whp in a recent dyno only gained 2 mph over a car that has 370whp. It just doesn’t add up. It’s one of two things or both. Either during actual multiple gear pulls power is seriously being lost or there is some deception here.
Honestly the math does not lie. Ive only place pure facts
A stock type r in 70 degree weather will hit 108 mph. With the weight and crank hp again put into the calculator it’s calculating 107.5 mph. So clearly adding power doesnt cause a steep loss in calculations.
This just proves the point that numbers on a dyno aren’t everything.
Can you do 400whp on 93 octane? Yes you can. Will it continually drive at 400whp HELL NO. 375whp is the max consistent power you can create with 93 octane.
So for me until the math adds up I’m not gong to take anything they say for real numbers.
Go back as far as prl prototype turbo on red star made supposedly over 480whp it went
124mph. It should be going 131 mph. That’s a 10 percent loss in mph.
Going all the way back to 2001 built block stock head cam gsr swap Cx hatch 60 trim turbonettics on c16 made just over 500 crank on 28-30 psi At 2300 lbs with driver it ran 10.5 at 141. The calculator said 140 mph.. This proveS Accurate to old and new cars.
Throw any car and correct curb weight and hp you will get 99 percent accurate mph.
he’ll let’s go real big a McLaren p1 makes 903 combined hcrank at 3075 lbs. it’s calculated by the rob robinette calculator to hit 155mph and I’ve found 152.2mph In real world results. At most it’s a 1.9 percent variance even at 900 hp level cars that use electric motor combination. This proves weight and mph are the best calculator of real hp. Electric motor doesn’t aid as much at high speeds so this could account for greater than 1 percent variance in mph.
So to the people talking crap another specific well known tuner his cars hit the mph to his rated hp. I’m talking civic type r civic si Honda Accord ect. New old Honda doesn’t matter. His cars add up. So don’t bash what you don’t know. I’m not bashing I’m stating that red star motors tunes do not add up using scientific data.
From a tuners perspective technically you can get more hp on a dyno but will it stay. No so that’s why I only try to post about repetitive possible numbers. I’ve only heard but haven’t seen in person that to gain the numbers a 13.0 afr is being used. The problem with this lean is it’s only good for a single gear before the piston starts to get too hot along with the cylinder and spark plug get too hot and start to either cause knock or Preignition. So after multiple gears you will lose power considerably. That’s how a certain person I know hit 400whp dynojet one time. I heard that “less cam timing” is being used. Increasing intake cam timing alllows the intake valves to open earlier in a turbo car to allow more time for cylinder to fill with air.This allows for less boost pressure to make more power. Less pressure needed before the cylinder equals cooler cylinder under compressed air. As an example cam timing alterations makes a very big difference on k24 turbo. 30-40whp on pump gas difference. Stock cam timing is always slightly more conservative. It’s emissions based. One last thing. Do not be fooled by egt in datalog. It’s calculated a lot by fuel volume and ignition timing. There is no actual egt sensor on these cars. It’s not accurate. Feel free to chose who you want to tune your car but think how many videos have you heard people make so much whp then lose to a car with considerably less at the same weight on 50mph roll.
please don’t bash people I’m only stating what is facts. I do not claim to know exactly what red star is doing with their tunes only what I’ve heard. I’m going based off their numbers and their times posted on their Instagram. Even a mediocre driver will come close to calculated mph vs hp. Judging from certain videos it isn’t a driver issue.
You do not have to believe what I’ve written.
