Red Emblems for Coupe
mis3
PT
Ontario
Mercedes, 2018 SI Coupe
I am getting the HFP red front lip and 2 red emblems for my 2018 SI.
I was given the following parts numbers:
1. Front: 75700-TGH-A01
2. Rear: 75701-TGH-A01
3. Lip: 08F01-TBA-182 (or 180)
I asked the dealership to confirm the parts number for my car. They said they cannot confirm since the emblems are made for CTR, not for SI coupe.
Can coupe owners here please help to confirm the parts number?
mis3
PT
Ontario
Based on your response, I went to measure the width and height of the two emblems. They are the same!
How about the pin positions in the back side?
geeeek
Daniel
Los Angeles, CA
Black Civic Hatch Sport 6MT
not sure if you'd want to do this, but you can just cut off the pins and use adhesive to stick on the emblems, especially since the red R emblems are a solid flat piece. I did that for both my front and back emblems (have the solid black emblems). I recently had to cut the front emblem pins after I got the procivic grille because I didn't want to order another one
Axatax
In Malkuth, surrounded by evil, low on gas.
2K Civic DX Coupe B18C5 (swap), 2017 Civic LX Coupe 6MT
There was a thread here a few days ago where there was some disagreement whether the emblems came with tabs, tape or not.
I can tell you for certainly the OEM chrome emblems on my coupe has tabs on both the front and rear emblems, with only the rear emblem having tape.
mis3
PT
Ontario
I installed two 75700-TGH-A01 on my coupe, pins lined up perfectly in the front and the rear.
Hey, we have the same cars! Do you install the emblems with pins or with double-sided tape?
casprog
Socal
2018 Si Coupe
I have a 2018 Si Coupe. I got my emblems from EdgeAutosport
75700-TGH-A01
I got 2 of those, it's the same size front/back, unlike the sedan. And it came with pins + 3m tape. I had to remove existing pins. The front was easy. The back was not as easy but I got it done. The back had some metal clips holding the pins in, so I ended up breaking the rear emblem off the pins then fished the bits out from the rear trunk liner... eventually I got it out. It's hard to not break the stock emblems during removal... very squishy.
mis3
PT
Ontario
I understand now.
The pins are there only for guiding, the double-sided tape is for securing the emblems.
JT Si
Place
Car
75700-TGH-A01
Wait, wait, wait, wait, wait, wait....
Is this one of the clips that holds in the OEM emblem?
Honda Civic 10th gen Red Emblems for Coupe IMG_20190925_221154
I've had two of these fall out when I've opened my trunk and I never had any idea what they were. Strangely, one fell out months before I removed the OEM emblem. The other fell out months after.
Rickmeister 48
Overlord
Newark De
2018 civic ex-t
Yea, but when you install the new emblems, there's absolutely no way to reinstall those without removing the bumper. I tried every possible thing I could, you just can't get to them, at least in the front.
My oem front emblem had no tape just as someone else mentioned, but the pins did serve to line up the new one ,which I used tape for and it was not going to come off,lol
