fatherpain
- Tom
- Dec 22, 2018
- 27
- 2,205
- 3,799
- SoCal
- Website
- www.civicx.com
- 2018 CTR - CW, 1996 Honda Accord EX coupe
- Build Thread
- Link
- Vehicle Showcase
- 1
Hey there godsmacksully,
Sorry to read you are having trouble. I have the exact same SGS28 and PF22 Foam Cannon setup so hopefully this helps:
Here is the Foam Cannon. The silver quick connect fitting on the upper left should be installed and tightened using a wrench. It needs to have white Teflon tape wrapped on the threads before you install it, to prevent leaks. Everything is clockwise to tighten, so you wrap the Teflon tape counterclockwise (opposite direction) so it doesnât unravel when you are threading in the fitting.
Foam sprays from the black plastic nozzle on the right. By turning it, the spray pattern adjusts from narrow to wide.
Unscrew the Cannon top from the bottle to add car shampoo. Dilute and add water to the shampoo instructions.
Here is the SGS28 gun with silver quick connect and green spray nozzle installed. For washing cars only use 40 degree or 25 degree nozzles. I use 25.
When ready to use the foam cannon, remove the green spray nozzle by pulling back on the silver quick disconnect...
Then pull the spray nozzle off.
Now you are ready to attach the SGS28 gun to the foam cannon.
Pull back on the silver quick connect, then press onto the foam cannon fitting.
And release. Now you should be good to go. Pretty sure the black plastic knob on top adjusts the amount of soap used when spraying. The nozzle on right adjusts the spray pattern, wide or narrow.
The thing that I am having trouble with is that all of the parts that screw into the holes in the foam Cannon to assemble it, they don't screw in all the way and I'm confused by it. I'm using a wrench to tighten it down as much as I can but it seriously feels like it's made for the wrong Cannon. The one I got was posted early on in this forum.
