Recall 18-137 Software update with A/C Control Unit
Dominus
Rick
Houston, Texas
2017 Civic Coupe Touring (Black)
I bought my car on 12/26. Got a call a couple days later from the service guys saying there was a recall. I took it in, it took about an hour and a half. Funny thing, they changed the oil and filter. Neither myself or the service advisor could think of a good reason why. I wasn't complaining, I'll take a free oil change.
Just giving you guys the heads up, you might want to call your dealer.
utparatrooper
Dallas
2018 Civic SI
Interesting. Do you know if this was related to the oil dilution remedy? Didn't think this had filtered to the warmer states yet.
Hondaman_MI
17' Civic EX-T
I think the goal is for the engine to warm up faster. To help alleviate rising oil levels. After all the attention the CRV got and China, they're just going ahead and doing Civics too, as a precaution it seems. Mine was updated today too.
Dominus
Rick
Houston, Texas
  • #4
Yep, that's exactly what my receipt said. If it's for the oil consumption/dilation issue, I wonder why they're acting like it's some A/C control update? I guess to not scare people?
d1zguy
VA
19' Mustang GT Premium
Because the AC module spins the aux fan too much not letting the radiator get to a high enough temperature
Fit2Hatch
Victor
Waipahu
Civic '18 Hatchback Sport MT, Modded C6 Corvette MT + E-tuned by ECS
There goes your factory filled "break-in oil".
WhiteCastleKid
Detroit
2018 Honda Civic Hatchback Sport Touring
Do not let them do the idle relearn, you dont need it. Your 1.5t turbo is to small and can overheat or blow a bearing. I have a family member that races, and he said going to 3k rpm’s for over 5 minutes is crazy with this engine. It is only for a conveience they do it. Your car can learn the idle with just some milage and a few start ups. I had my recall done, and they did not do the idle relearn, and it is just fine with 30 miles on it since the update. No sense in doing this to a new car. My car is not even broke in, why chance it.
SCOPESYS
Geoff
MD
Raises some basic questions:
(1) Is the Honda Civic always relearning the Idle, or does it need to be put in a re-learn mode ?
(2) What is likely to happen if I tell the Dealer NOT to do the re-learn.?
(3) What is involved in doing the re-learn, if it's a IDLE re-learn, why does the Turbo have to run at excessive speeds ?
WhiteCastleKid
Detroit
You are suppose to have a idle relearn after a TCM or and PCM update is done, along with a throttle reset. These are done by computer. But the idle relearn will have you running the engine while in park to 3K rpm until the fan kicks in (turbo gets real hot) and then let it idle for 5 minutes on it own. The ECU has the base idle already programmed, but factors like out temp can change these. Let’s just say, your car is alway learning about temp, you and how you drive. Just ask not to have it done, and I am sure a good mechanic will ablige.
Spacesloth
Wisconsin
2017 Honda Civic SI
Running the car for 5 minutes at 3k rpm is not going to hurt anything, it’s not under any load, everything is being cooled with coolant and lubricated with oil. The turbo is not creating any boost. If this was an issue with any manufacture, engines would be blowing up left and right. Additionally, you do realize an SI sits at 2500-3000 rpm at freeway speeds, older NA engines spun higher yet and have gone hundreds of thousands of miles problem free. Please don’t spread misinformation.
SCOPESYS
Geoff
MD
Not wanting to take sides here, but I would tend to agree with you.
If the engine cannot run at 3000rpm in Neutral (Thinking Si), then it is going to be bad news very soon under normal driving.
jgreen16
Cleveland, OH
2020 Civic EX Hatch, 1990 Chevrolet C1500
And for the impatient, go ahead and do 6K rpm for two and a half minutes. Off and up on out in half the time. :rofl:
