Brisco
- Matt
- May 14, 2018
- 61
- 590
- 102
- Kitchener
- 2018 Aegean Blue Civic Touring
I have put a Tee harnesses kit together for use with the accessory plug that is molded into the taillights as well as Tee harnesses for the brake light plug and signal light plug.
These kits work for Sedan and SI 100%
For Hatch The front signal, rear brake and accessory/parking harness will work.
These will not work for the REAR signal currently for hatch and Type R. (Connectors NOT available) They have a different signal connector.
(I have confirmed these will not fit coupe at all)
With this set of 4 harnesses or 6 harnesses you can finally install those bumper lights or rear window brake and signal lights you’ve always wanted to install without hacking the factory harness.
Below is a picture with each harness needed and their prices.
I needed to tap into my accessory and brake circuit to add lower bumper lights (where the reflectors are) the right way. I needed the 4 harness kit.
I have brought a few in to make tee harnesses in case anyone else needs a set.
Pictured below you will get two of each of these colour coded harnesses.
All of my harnesses use the oem style connectors and are watertight.
Save on shipping with purchase of my other harnesses.
