RAYS CTR FK8 Spec Wheel Options
Si_chRis
Connecticut
2000 Honda Civic Si, 2018 Honda Civic Type R
Had my CE28 Club Racer 2 Black Editions (18x9.5 +38) mounted with OG decals, and Continental Extreme Contact DWS06 tires in 255/40R18.
Still waiting for my center caps from Japan to arrive.
Honda Civic 10th gen RAYS CTR FK8 Spec Wheel Options PXL_20210728_150801598
FK978
Sid
Massachusetts
2020 Honda Civic Type R
How do you like how this setup rides compared to stock?
Si_chRis
Connecticut
It has been a while since I have been on the stock wheels and tires (over two years ago). Trying to remember how it felt, the steering response was sharper. With 18's and a 255/40 tire, the ride is way more comfortable and compliant, but steering feel is less sharp. I have not ran a summer only tire before, only high performance all seasons, even with my other setup which are TEs in the same spec as my CEs. I would imagine summer only tires ride a bit different than high performance all seasons.
I also run a winter setup using 18x8 wheels and a 235/45 tire. The ride is even more comfortable and refined, but winter tires always have less reponse and steering feel.
FK978
Sid
Massachusetts
Thanks for the response. I really appreciate it. I usually run the DWS’s as well and I’m happy with their street application around here in New England. Also, not planning to lower the car so it’s interesting your mention about less steering sharpness.
Si_chRis
Connecticut
Not a problem. The DWS06 is a great tire. I had them before on another set of wheels and ended up getting them again for my CEs. I wanted the new DWS06 Plus but they were backordered at the time. I believe a combination of thicker sidewall, wider tread, and wheel size/offset all play into the feeling being different than stock. For me, I just could not daily drive with the stock setup.
AygunRajabova
Aygun
Georgia, USA
2019 Honda Civic Type R (R-31655)
Rays Gramlights 57DR 18x9.5 +38 Gun Blue II
FIREHAWKS 255/35/18
Project Kics Lug Nuts
Installed today and no rubbing!
Heya! I'm getting 57DRs and I was wondering what valve stems you were running? Do the Rays valve stems work with DRs?
AygunRajabova
Aygun
Georgia, USA
Gram Lights 57DR 18x9.5 +38 5x120 in White with Michelin Pilot Super Sports 255/40/R18.
Shout out to System Motorsports!
Heya! I'm getting 57DRs and was wondering what valve stems you were running. Do you happen to know if the Rays valve stems work with DRs?
Si_chRis
Connecticut
57DRs should come with valve stems. However, the Rays aluminum ones will work as well.
AygunRajabova
Aygun
Georgia, USA
thank you!!! I found some fromSystem Motorsport. The wait was minimal (only 2 months) and they come with spoke stickers:)
un1coRn
IG: @sgp_fk8r
West Palm Beach, FL
2019 SGP FK8 R-34844
Considering doing this to mine but I just rock no decals
FK8_Kenji
Kenmore, WA
Hi All,
I bought some 57dr 18x9.5 et 38 offset for my stock suspension Type R.
I was wondering if anyone was running the Continental ExtremeContact DWS06plus at 265/40/18?
My car is full bolt on and has a custom tune pushing around 400hp. I was wondering if I should go 265/40/18 or 255/40/18?
I live in the Seattle Greater Eastside and don't drive into Seattle. I think the roads are relatively fine.
Just concerned about rubbing.
Sorry if this has been brought up before, but I couldn't find someone with this specific set up after reading for like 2 hours. Maybe my search skills just suck too.
Tev42
Tyler
San Diego
2019 CTR
Hi All,
265/40 will rub for sure. 255/40 rubs the tiniest amount on big dips but is fine 99.9% of the time
also 265/40 looks kind of goofy, I saw a pic once and it’s too much tire
