Rattling Noises from engine compartment or under car
croozer2000
Utah
2017 Honda Civic Hatchback
I have a rattling noise that begins around 70MPH and goes to about 80MPH. It sounds metallic and seems to be coming from either under the gear shift under the car or in the engine compartment. I'm trying to find where exactly its coming from. I'm just wondering if the location and the type of sound seems to be something loose or do you guys think it is some serious mechanical issue?
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
check the lower engine cover plate. they get loose or folks don't secure them properly and they can rattle like you described.
SirVicksDeep
Simon
Charleston SC
2019 Civic SI
Check to make sure your hood bar is locked in place. If it isn't it will raddle against the frame and make a noise at different RMPs
croozer2000
Utah
I started smacking the bottom of the splash guard. I believe the issue is not the lower engine plate section now, but the plastic area under the drivers side seat.
davidgostbo
Texas
Honda Civic Ex-t 2016
Please update me if you find out whats wrong. I've been trying to isolate this exact same noise driver side somewhere underneath dash
croozer2000
Utah
I Have not had time lately to check out the issue, but I will post when I find it.
croozer2000
Utah
Sorry I have not messaged lately. It turns out it’s rocks getting stuck under the splash shields. A air compressor would help or you may have to take out by hand some of the more stubborn rocks.
