Random blue smoke when decelerating but will be gone after 2 secs.
Si Is Life
Bush1do
Civic SI 2020
So im having this issue that i can't find any clue on whats wrong with this. I just recently installed my rv6 drop in turbo and at this time my car smoked atleast two times now when decelerating but nothing on idle and when accelerating and it seems to happen randomly. Thank you for anyone that can give answers!
Si Is Life
Si Is Life
Bush1do
Civic SI 2020
As far as i see i think its coming out from the back
Sport-injected
Scott
Central Jersey
www.youtube.com
Check that all of your lines are hooked up correctly on the turbo, also you should remove downpipe and look in turbo to see if you see signs of oil. Reach out to RV6 if you do see oil in turbo. Did it smoke before the turbo install?
Sport-injected
Scott
Central Jersey
www.youtube.com
Bad rings?
That would be a bummer, if I read his post correctly it did not smoke before he installed the turbo so would almost make sense it would be related to the turbo, but anything can happen. That would be worse case lol.
LBP
Sounds like a weeping/leaking seal in the turbo. It happens. RV6 should be able to take care of you.
Si Is Life
Si Is Life
Bush1do
Civic SI 2020
Yeah imma check the turbo out in my off gotta see if there is some leak and im only 16k miles and car is barely beaten would be a real bummer if its the rings already 🥲
Boosted_01_R
2020 FC3
Doubt it's piston rings unless the motor has seen a lot of detonation, sounds turbo related. Check your oil return on the turbo, make sure no kinks or blockages. Curious what RV6 says.
Sport-injected
Scott
Central Jersey
www.youtube.com
I would go ahead and email Rich @RV6 now to get his thoughts and just so he has a heads up. He may have a simple way to check.
Hope it is something simple.
Sport-injected
Scott
Central Jersey
www.youtube.com
I foun
d it now oil return line is leaking gasket went bad for sure its a simple fix thank you guys for helping!
Great! Glad it was simple!
Si Is Life
Si Is Life
Bush1do
Civic SI 2020
Nope never mind i wiped it down and test drove the car and its not the return line that is leaking its the middle part of the turbo with the clamp thing
Honda Civic 10th gen Random blue smoke when decelerating but will be gone after 2 secs. 20220518_171238
