Pull on highway feels like loosing power
415_CTR
Felix
Fk8
I did a pull after a catless downpipe on highway and felt the pull .. 2 seconds later it felt like power died ., any help?
kefi
oh shit waddup its dat boi
Central Florida
fk8.clinic
2018 Type R
Are you tuned? You probably maxed out your fuel pump because the catless downpipe let more air flow through than normal. Factory tune and Hondata basemaps handle this differently but usually 'power loss in the middle of a pull' is fuel pump related.
415_CTR
415_CTR
Felix
Fk8
  • #5
it felt like it misfired back fired 🤔
415_CTR
415_CTR
Felix
Fk8
  • #6
What map are you using? I usually only work with Hondata but I can take a look at a datalog if you manage to replicate this while recording.
I am
Using stage 1.1
kefi
Central Florida
fk8.clinic
2018 Type R
Hmm. Strange.
There's no traction control on KTuner besides the factory traction control, so it's not like it was retarding ignition for wheel spin.
Did this problem only start after you added the downpipe? I can't really tell you much more without seeing a datalog of when it happens, sadly.
415_CTR
415_CTR
Felix
Fk8
  • #8
I couldnt get my secondary 02 sensor to fit with defouler.. think that’s the problem?
415_CTR
415_CTR
Felix
Fk8
  • #9
Hmm. Strange.
So as of now I just have it connected and attached to the frame not inside downpipe ( secondary 02)
EnjoyDriving
Minnesota
2018 CW FK8
Have you checked out an O2 sensor extender? I have read some good results coming from that product, and it can fix the cel issue too.
kefi
Central Florida
fk8.clinic
2018 Type R
I don't think that would cut power, it would just throw check engine lights. But I don't think I've ever heard of someone leaving it plugged in while attached to the frame, either, so I could be wrong.
Did the loss of power remain after or did it just not pull as hard one time?
415_CTR
415_CTR
Felix
Fk8
  • #12
I felt it after the downpipe install so im
Guessing after the 02 sensor has not been plugged in downpipe
415_CTR
415_CTR
Felix
Fk8
  • #13
Would it be too much of a high gear pull?
415_CTR
415_CTR
Felix
Fk8
  • #14
I’ have no cel I disabled them on k tuner
jtrader
James
OH
2018 Civic Hatch Sport, 2009 Odyssey
This may sound like a noob move, and probably isn't your problem, but I'll tell it just for kicks. My DIY cold air intake came loose one time, the MAF sensor and all. Man, the car does not run well at all with the MAF disconnected. It did run though, which surprised me. I was so relieved when I saw what the problem was. Easy fix, but I was quite worried during that commute.
