Public Service Announcement: Si Fuel Injectors
Design
Southern California
09 MS3, 17 ABM Si Sedan
I was quite surprised myself. After doing a bit of digging, and as mentioned earlier in this thread, this appears to be their third mass injector failure in under 5 years. Why they didn't rotate in another supplier like Denso is beyond me.
I've heard there are still over 2K prepaid orders in queue.
Design
Southern California
And to clarify, "first come first served" simply means waiting in line after placing a CBO through the dealer.
Boosted_01_R
2020 FC3
Do they look any different externally ? Any meaningful change will be internal, just curious.
Los1391
Carlos
Westchester NY
2018 CBP Si Sedan
can you post a photo by any chance?
Design
Southern California
Here are a couple photos. The kit includes the fuel joint (not fuel pipe) which is strongly recommended to be replaced due to the crush assembly.
The part ID for the injectors is similar but includes an extra 0. To my knowledge, these can no longer be purchased independent of the fuel joint. The sub-part includes injectors, seals, and clips.
Full kit:
Honda Civic 10th gen Public Service Announcement: Si Fuel Injectors IMG_2658
Injectors, seals, and clips:
Honda Civic 10th gen Public Service Announcement: Si Fuel Injectors IMG_2661
Fuel joint:
Honda Civic 10th gen Public Service Announcement: Si Fuel Injectors IMG_2663
Honda Civic 10th gen Public Service Announcement: Si Fuel Injectors IMG_2659
cota
jaiden
New Jersey
2018 Civic Si
anyone have the ebay link for the injectors?
Sadé Smoove
Evan
2018 Civic Si Coupe
You should be able to find it with part number 06160-5PA-305
WOPSiWOT
South Carolina
2024 Civic Type R | formerly 2017 Civic Si Sedan
You won't find that on eBay as that is the new PN on national backorder. The old PN was 16010-5PA-305. That's what you'd be looking for. Hopefully from a reputable source. A lot of those eBay sellers look rather shady.
Sadé Smoove
Evan
2018 Civic Si Coupe
Ah yes You're correct.. I saw quite a few of the old injectors up on eBay but like you said they seem to little shady plus you truly dont know the quality you're getting. Could have been used 100 miles or 100,000 mi 🤷🏾‍♂️
Sadé Smoove
Evan
2018 Civic Si Coupe
Anyone know where to order from that is the cheapest/ most reliable for the new injectors ? I feel like I might as well put myself on the waiting list since I'm already at 66k miles. I imagine it's just a ticking time bomb at this point
BigDog
Minnesota
'18 Si Coupe, '24 Colorado
Had one of mine go bad @ 132K miles at the end of June. Waited a little over 4 weeks for a replacement set to come it at the dealer. Dealer was 1,156 in line on the back order list in early July. Got my car back in early August.
cota
jaiden
New Jersey
2018 Civic Si
Update: 9/1/23
Got my car diagnostics tested by my local honda specialist for p0219F code and he concludes it's the injectors.
He told me the revised injectors from Honda are about 3-4 day arrival from ordering today. Pretty much said the backorder isn't bad anymore.
~$600 for the parts: Injectors and Pipe Joint
~$420 in labor
Called my other local shop to see if the price in labor is fine and he says it's a good deal for it being about a 4 hour job. I'd do this myself if I was more patient and had all the tools.
Hoping to not run into any issues with this car for the next 4 years. or else I'm getting an s2k
If additionally your fuel trims look bad, it's likely an injector issue.
Interesting. I replied to your message about that code with this answer a few weeks ago.
