PTP Turbo Inlet Pipe Blanket
alejandroads123
Daniel
Civic type R
I havet the inlet thermal gasket, plus the thermal washers. I will post results soon with the blanket.
I will be waiting very anxious!!
Thank you!
CincyTypeR
2017 Type R #0426. 2014 Accord Coupe V6
If we have change on the IAT2 lower temp with inlet pipe blanket it meaning it worth it. Course the inlet pipe need the thermal gasket also.
Isn't the IAT2 temps at the intake? So the reading will be the temp before it even hits the inlet pipe.
CincyTypeR
There is a lot a cross information, but make more sense IAT after intercooler because is compress air, (always higher ) and IAT2 intake.
Correct.
The IAT reading will vary on multiple variables (outside temp, speed, boost vs vacuum, temp of the turbo, ect). So I do not consider that to be a representative figure either for the inlet tube temp.
SloPoke83
Ben
Jacksonville, FL
2018 Civic Type R
Would the blanket be more effective than having your inlet pipe ceramic coated like the Down Pipe and Front pipe?
alejandroads123
Daniel
Civic type R
I have compared in others elements ceramic coated vs blanket and blanket was more efficient. ( was a electronic device, but thermodynamic is the same )
CincyTypeR
Any guides out there to remove the inlet pipe?
alejandroads123
Daniel
Civic type R
Did you feel any difference in power after the intake blanket? Any difference in temperature?
He mounted yesterday night, today is too could for testing, probably we have to wait for result, I'm waiting for the same here.. Very anxious !!
averagetrackdriver
Virginia
2006 S2000
Would installing the inlet and turbo blankets on CTRs that are tracked in hot and humid conditions make sense, or would they retain heat in such conditions? I'm asking b/c I've gotten different opinions from track drivers.
FK8_K20c1
Jonathan
Indiana
FK8 Type R
Not that hard to do, whats difficult was the 2 bolts that bolts the inlet to the turbo(tigh space). I have the p2r thermal gasket on the inlet pipe where it meets the turbo so it was hard to align it and bolt it. I dropped my flashlight twice and had to lift the car and remove the belly pan 2 times. It was freezing cold last night and this morning 16-19 degress. I did like 4-5 pulls but the car cooled down on the 10 minutes back to the garage. The inlet pipe was cold to the touch. I will report back when temps go up.
8yourv8
Michael
Dothan, AL
2018 Civic Type-R
Is this a good item to run if you dont race the car and only drive 3000 miles a year? I mean i use to drag race my Evo a lot and never wrapped anything but yet i see all these pipes being wrapped. Again just need some info
