Pros and Con TSP Stage 1
Sharingan
Washington
Civic Si 2018 Coupe
Been reading a lot on this forum and see many positive reviews about the TSP Stage 1.
Relatively a beginner with the whole tuning/modding community
Can anyone name Cons for using TSP stage 1, I was thinking that the base tunes that come with Ktuner would satisfy my needs. I just want to make my daily driving a little more fun, no need for anything too crazy for me.
I only ask because I see countless of people saying that once they go to Tsp stage 1, they can't go back to Base map. I am worried about the possibility of engine harm if I do go with TSp though. Again, still learning about everything and just wanted to know if I would be fine staying with stock base map.
julianzh
Quincy
2016 Civic EX-t, 2019 GTI Autobahn DSG
I went back to the base 21 because tsp 1 jerk so much during traffic and low speed. Even after adjusting the boost for 1st gear, it still happening.
Sharingan
Washington
Civic Si 2018 Coupe
Thanks for your feedback, that is quite a dealbreaker for me as I commute to school and work.
fenix-silver
Central PA
2019 Si
This is due to disabling rev-hang and it's really only an "issue" when you are creeping along in traffic. You can either turn it off altogether in the map before you upload it to the unit or use the cruise control button to turn it on/off.
Sharingan
Washington
Civic Si 2018 Coupe
Just to clarify, this disabling rev-hang can be done on the fly right? Like while I am driving. Ive heard many positive things about disabling rev hang.
julianzh
Quincy
I didn't know cvt has rev-hang
fenix-silver
Central PA
2019 Si
Yup, with cruise enabled (not necessarily set), rev-hang will be like stock.
To answer the OP's original question, the KTuner starter maps are good and if you want something conservative, they will work just fine.
The TSP 1 is an upgrade in both power and overall smoothness. The biggest negative being some people have had some clutch slippage especially on Map 3. The beauty of KTuner tunes though is the on the fly map system that gives you 3 maps of various levels of boost.
With my TSP setup, I like to use the lower power maps most of the time and then use Map 3 for "special occasions". :cool: That way, I can keep wear and tear down and reliability up.
