PRL Motorsports Front Pipe - Fitment Rattle - Installation error?
Myx
Delaware
MOD EDIT: After reading this thread in full I added "- Installation Error?" to your title because that appears to be the case here. I didn't want PRL to get any negative press for an issue that was not their fault.
Op Edit: Even after correcting the installation error (No cat convert stay was installed previously), the rattling happened again on another brand new front pipe install.
I had some fitment issues today with the PRL Motorsports front pipe today. I made a quick video and uploaded it so you can see the location that I'm talking about. It is the connection between the front pipe and the stock midpipe (Or B-pipe it may be called?). There was a 1" gap between the two that could not be connected. Not sure why this was the case.
Also, right at this same location the PRL front pipe flange contacted the heat shield there. I had to have that slightly modified so that while the PRL front pipe moves, it would not hit this and rattle. If you have any rattling issues with the PRL front pipe itself, check this location and see if the heat shield is coming into contact with the front pipe itself.
The PRL Motorsports front pipe and downpipe I had installed, was installed just fine. No issues there. These are just things that my shop encountered. I will try to post several pics later and possibly an extra video or two. I have to run out with the Misses to take care of several things. Just sharing!
Honda Civic 10th gen PRL Motorsports Front Pipe - Fitment Rattle - Installation error? PRL Downpipe to Stock Exhaust 1
Honda Civic 10th gen PRL Motorsports Front Pipe - Fitment Rattle - Installation error? PRL Downpipe to Stock Exhaust 2
Myx
Myx
Delaware
Still getting rattling from time to time. I did have a few adjustments made to the exhaust area around the exhaust to try to avoid any rubbing. Last area is the where the front pipe makes this upside down u-bend towards the rear exhaust. It's not touching now but as the engine/tranny moves, it makes contact.
So if you hear stories from anyone about any rattling after installing the PRL frontpipe or downpipe, heads up.
ferdinand
Minnesota
2016 Honda Civic Touring, 2019 BMW X2 M35i
Hope you get the rattles sorted - they can ruin the best sounding exhausts...my rattles (on past cars) usually came when the exhaust heated up and expanded ever so much after some "spirited driving". If your tolerances are super tight, then you will probably have contact after the exhaust gets hot.
Myx
Myx
Delaware
I got my rattles sorted out alright. I removed the PRL Front Pipe piece and tossed it out. I now have the stock front pipe installed along with the stock exhaust all the way out to the two mufflers. Tossed out my 3" Hybrid Injen exhaust as well. Car is quiet again and still feels just as powerful. I don't go by feeling though so I have to test it at the track. Best of all, no more rattling. You live and learn.
I've included pictures below of where the PRL Motorsports Front Pipe and intermediate drive axle were in contact with each other. If you have any rattles with the PRL Front Pipe, be sure to check this location as well as others. Just a heads up!
Honda Civic 10th gen PRL Motorsports Front Pipe - Fitment Rattle - Installation error? Front Pipe Rub - 1
Honda Civic 10th gen PRL Motorsports Front Pipe - Fitment Rattle - Installation error? Front Pipe Rub - 2
Honda Civic 10th gen PRL Motorsports Front Pipe - Fitment Rattle - Installation error? Front Pipe Rub - 3
Shankmeyster
AZ
23 Si
Now THAT is a nice little gouge. I thought the flex section was supposed to negate things like this. So far no rattles on the front pipe that came with my exhaust thank goodness.
invader
North-Eastern Ontario Canada
2019 Corolla Hatch SE 6-spd
ayeerock
Aaron
2017 Honda Civc FK7 Sport
down pipe fitting good tho?
Myx
Myx
Delaware
ferdinand
Minnesota
I wonder if this is a cvt issue? Anyone running the PRL front pipe on a cvt without rattles?
davemarco
@PRL Motorsports Apologies for tagging you, but I am planning to order these parts come the Spring and my primary concern has been fitment and avoiding more rattles than I already have (which would drive my OCD wild). It seems that there was a pretty substantial gap in the OP's picture of the front pipe. Would you be able to provide any feedback on this? Hoping that it was just a random outlier. Thanks!
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
Moderator....can you please change thread title to say 'PRL Motorsports Front Pipe - Fitment Rattle?
This is the first time that we've ever heard of anything like this. We have not had a single fitment issue since the first batch of 10-15 months ago and have now sold over 100 kits. All downpipes and front pipes (like everything we make) are fitted, welded and test-fitted in a jig, so fitment is the same for all. Fitment is very tight through the power steering area due to the fact our front pipe uses 3" tubing, but it can be massaged and fitted through there without any rattling issues. Remember that these cars are manufactured on a production line, so there can/will be a bit of fitment variance due to "slop." This is one of the reasons why we implement a flex section in our design, to allow for these minor variances.
Judging by the pictures, it appears that there is some sort of issue towards the downpipe connection/installation. The front pipe should be nowhere near the intermediate shaft.
  • Was the downpipe-to-turbocharger connection left loose so that the downpipe could be appropriately rotated/clocked to allow for proper fitment through the downpipe/midpipe assembly connection? This is the most common install error, as we have received quite a few calls and emails about this.
  • Was the downpipe bracket connected to the proper side of the flange? We have seen a few customers install the bracket to the wrong side, causing the downpipe to be pushed the wrong way, causing front pipe fitment issues.
All connections should be left loose to allow for proper fitment adjustment.
With that being said, we are always willing to answer any questions, it's just difficult to keep up with every single communication outlet. A phone call or email is always preferred and prioritized. This could've prevented this headache. :(
Myx
Myx
Delaware
@PRL Motorsports
I have no idea on the two points above. Shop installed it. I drove off without issue. Then when making a sharp turn or sometimes during acceleration, the banging/rattling started. The piece was damaged so I replaced it with my stock front pipe. No more banging/rattling. I thought installation would've been straight forward, without any specific items to try to avoid. Here is what I suggest. And I'm only suggesting this as a customer of yours (I ordered your Front Pipe/Downpipe as well as have preordered your intercooler, CAI and CVT Cooler).
Include a slip of paper that states the following items to your future customers on the front pipe installation:
1) Leave the downpipe-to-turbocharger connection loose so that the downpipe could be appropriately rotated/clocked to allow for proper fitment through the downpipe/midpipe assembly connection. This is the most common install error, as we have received quite a few calls and emails about this.
2) Connect the downpipe bracket to the proper side of the flange. We have seen a few customers install the bracket to the wrong side, causing the downpipe to be pushed the wrong way, causing front pipe fitment issues.
With this info included in the future packages of frontpipes shipped, you should not have any more calls (Or much fewer calls) about this.
Just making a suggestion so no-one else may potentially run into this issue. I had no idea what caused this and I had no resolution. The damage was already done once installed and driven and the rattling started. If this information was included in with the shipping of the front pipe and downpipe, I could have possibly avoided this whole scenario.
ecarranza11
Palmdale
2016 Honda Civic Ex-T
Hey I had a shop install my downpipe and frontpipe as well, when I drove off I have no problems until a couple days later I kept hearing the fringing noise.
I was on the list of preorders when the products just came out and I have a CVT.
Today I finally had time to lift my car and see where the noise was coming from and it's the same spot as @Myx
What can I do to fix this problem?
ferdinand
Minnesota
Is anyone running the PRL front pipe on a CVT without these issues?
