PRL Motorsports 2017+ Honda Civic Type-R FK8 High Volume Intake System
Higgo8
Steve
Stoke-on-Trent
2017 FK8 CTR GT
Injen is not even worth mentioning. Do some search there is enough data out there. To give you a hand look on fb type r groups everything is there.
Yes, again, it would be good to get a good one stop has done all, on same car dyno etc as the true comparison.. There are other names out there, which I have not included - but hopefully you get the gist of what I am trying to say :)
FK8_K20c1
Indiana
MKV R32, FK8 Type R
Oh yea I do but, I would be impressed if they invest in all those intakes for a test that is not worth the amount of power it gives.
frtorres87
Frank
New Jersey
2017 Honda Civic Type R
Can this be released already?
davemarco
New York
2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
I'm curious what tweaks PRL has made to this design that allow it to best the similar designs from Mishimoto and Injen. I've read that those intakes have shown decreased performance once the ECU adjusts and the heat rises.
02SilverSiHB
Annapolis, MD
2017 FK8
where did you read that
davemarco
New York
I'd have to dig for it. I had come across a few sources previously (both here and in Youtube dyno videos) that had shown that as the ECU adjusts, the power figures dropped back to stock (or in a few cases, below stock). I believe that the lastest video that I saw showed that the Injen intake was subject to this.
I suppose that I'm just wondering what differentiates this new intake from Injen, Mishimoto, or even the stock airbox? I have PRL's Cobra on my SI, which extends down into the wheel well - I'm curious why they switched to a short ram with a heat shield for the Type R?
02SilverSiHB
Annapolis, MD
2017 FK8
I honestly dont think any intake can help that much...but when you mentioned those dyno vids showing lower numbers after a while...couldn't it be heat soak to the IC also...given that they really aren't driving it and just using fans? Just so many factors honestly.
As for injen, I believe that has to be the worst since it didn't protect against as much heat.
Either way, guess we'll see. Be great if someone did some serious comparisons with all kinds of scenarios..but who's got time/money for that, lol.
PRL Motorsports
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
  • #24
The Type R has a very good set up for the stock airbox so we felt its best not to redesign the wheel, but rather improve upon it with our intake with the largest airbox design available to allow the most airflow possible (less restrictive) around the filter material, plus a MAF design that you can be confident will be in line with Honda OEM fuel trims. :)
DeVo
Austin, TX
2019 Civic Type R #21399
I had the Cobra intake on my 17 Si. Will this also go down as far behind the wheel? I recently moved to an area that can flood frequently and am trying to avoid something that can hydrolock as easily (not the the Cobra ever did to me. it was great!)
forrestbb
Forrest
San Mateo, CA
2018 RR CTR, Civic SI-2008 sedan
Fyi, As side note as for intakes effecting especially with tune, Vivid racing claims with their tune for ctr, it will not alter nor have any ill affect even after adding any mods ie intake, exhaust etc.
http://www.civicx.com/threads/vivid-racing-eventuri-carbon-intake-special-offer.32132/
"Performance Increase : 14-20hp, 22-29ft-lb
V-Box Acceleration : 60-130mph Reduced By 1.2 Seconds"
vs :
Mishimoto:
  • Direct fit for the 2017+ Honda Civic Type R
  • Provides max gains of 16.7 whp / 20.1 wtq while maintaining safe A/F ratios
  • 42% increase in flow over the stock intake system
  • No tune required
  • Silicone elbow eliminates restrictions and improves and increases airflow capacity
  • Extremely aggressive intake tone under acceleration
  • Precision-adjusted CNC aluminum MAF housing allows for better flow
  • Powder-coated black airbox keeps unwanted hot air from entering the air filter
  • Mishimoto high-flow oiled air filter receives maximum airflow from the front of the vehicle
  • All black mounting equipment retains OEM+ aesthetic under the hood
  • Mishimoto Lifetime Warranty
oh and please make sure it's CA exempt for us Californias too Tks.
FK8_K20c1
Indiana
MKV R32, FK8 Type R
Overall the ECU is designed to protect itself there wont
vs :
Mishimoto:
  • No tune required
vs :
Mishimoto:
  • No tune required
There is no way the mishimoto intake will give you 20wtq I have to laugh at this. ECU will learn any mod you put on and adjust itself. Best mod per monney for a stock ctr is intercooler and catless downpipe if you dont want to touch the ECU.
17CivicTypeR_Brian
York PA USA
As with the Stage 1 intake, I'll be jumping on the intake(s) for the BTurismo Type R as soon as possible to get to the dyno at IMW. Not sure if I'll have it any earlier than anyone else, but I'll try.
I won't have any other intakes available to test against but I can at least show the before-and-after on the same day most likely.
I don't know any more info than you guys do!
davemarco
New York
Would you be willing to drive the car around for a bit after install but before your "after" dyno to demonstrate the gains after the ECU has had time to adjust?
17CivicTypeR_Brian
York PA USA
Ooh good point. I'd like to but I might have to pay for that time to hold the dyno open for when I get back... I'll try to work that out with IMW.
