PRL Motorsports 2016+ Civic X 1.5T Testing
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
We took another look at our 2016+ Civic 1.5T Downpipe and decided to develop a version 2. Don't worry, we kept the full 3" setup, and the performance has stayed the same! The revised downpipes feature 304 SS cast ends with standoffs incorporated in the casting to allow the factory heatshield to be installed. These cast ends are machined in house for proper mating surfaces, as well as drilled and tapped connections. As with all of our exhaust pieces, these are fully back-purged on site for weld integrity and optimal strength. Similar to our Version 1, there are no step downs inside the pipe to provide a maximum flow with a perfectly matched opening (to the turbine outlet) to 3.00" ID throughout the entirety of the downpipe. Choose between a catless (Race) or 300 CEL custom coated cat (Street). As per the version 1, there will not be a way to guarantee no CEL codes unless users turn it off via Hondata or KTuner.
To follow suit with most PRL products no cutting, trimming or other modifications will need to be done. All kits will include our signature gaskets, stainless hardware, and components required for a seamless installation.
*Be aware that the hardware has changed slightly from Version 1 to Version 2.
Check it out here:
https://prlmotorsports.com/civicxdownpipe.aspx#.XBpJvs1OmUk
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catless%20Downpipe%201.5T%20Civic%20with%20Hardware_zps8rydh9qx
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catted%20Downpipe%201.5T%20Civic%20With%20Hardware_zpsbp1fdvpb
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catless%20Downpipe%201.5T%20Civic%205%20Bolt%20Angle_zpsi1homqxr
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catted%20Downpipe%201.5T%20Civic%205%20bolt%20flange%20side_zpsnjhvfe1
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catless%20Downpipe%201.5T%20Civic%20Bracket%20Angle_zpsec1gufkk
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catted%20Downpipe%201.5T%20Civic%20Bracket%20alt_zpschyo3zvn
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catless%20Downpipe%201.5T%20Civic%20%20Heatshield%202_zpsaksqp78x
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catless%20DP%20Bung%20Close%20Up_zpsjh8ylhav
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing V2%20Catless%20downpipe%201.5T%20Civic%20Top%20Logo_zpsfq5gjbin
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
:respect:
Turn10Photos
Jordan
Las Vegas
www.turn10photos.com
FC3 Si, FK7, HRV
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
civictrooper
Jonathan
Connecticut
2018 civic si sedan
Check it out here:
So will version 2 show codes an need ktune to turn off or is it direct bolt on no worries
Thanks
civictrooper
Jonathan
Connecticut
2018 civic si sedan
Turn10Photos
Jordan
Las Vegas
FC3 Si, FK7, HRV
You get any codes popping up I don’t have ktune or any of that just trying to do bolts on for right now
Thanks
No CEL yet after 25 miles or so. I will let you know after how many miles it appears.
Its only a matter of time before it throws a code. There is enough room in that area to install a CEL delete. Wether it be a straight out attachment or even the newer 90° pieces they have. Wether they work on these cars I do not know.
If the opportunity presents itself definitely get a ktuner for this, best bang for the buck on our cars.
Honda Civic 10th gen PRL Motorsports 2016+ Civic X 1.5T Testing IMG_20181229_003030
dc2turbo
usa
civic,teg
an adjustable defouler will work depending on your driving style.
It works great on the highway but not so much with short city driving
Kane666
Jason
Pennsylvania
2018 Civic Sport Touring
so no performance difference? just you can use heatshields?
Turn10Photos
Jordan
Las Vegas
FC3 Si, FK7, HRV
Any catless downpipe will throw a CEL eventually. I tested it twice today and it came on around 30 miles again. My state requires yearly smog so I wanted to make sure a yearly install swap wasnt needed.
Wonder why certain brands will throw a code while others don’t
