PRL Intercooler Test Results
17CivicTypeR_Brian
York PA USA
I live in Denver, are the fuel demands going to be even higher at high altitude?
Should be the same or less if anything. The combustion process and ratios don't change because of altitude. The Turbo may not spool up the same at altitude but it should work to give you the same air volume that you would be appropriate for the RPM. At least that's how I would hope the ECU with electronic wastegate (boost control) would work.
3925blue
Texas
2018 Honda Civic Si sedan
The boost will be higher in numbers to compensate for less dense air, so the mass of air will be the same, therefore the volume of fuel will be the same. The small variance in density of fuel due to temp is accounted for by way of lamba. If you are running rich or lean, the ECU will attempt to correct after it sees the result that the O2 sensor gives it. That is what short term fuel trims help with.
EricDET
Cincinnati
2018 Honda Civic Type R
From what I've seen on most turbo cars... People in High Altitudes aren't going to see the same HP numbers as others. Higher shaft speeds can/will take the compressor out of its efficiency range and what the factory intercoolers can handle. Obviously all of this will require less fuel.
17CivicTypeR_Brian
York PA USA
Also the heat exchangers are less effective because of the ambient air density.
