KTuner
- J.R.
- Jul 10, 2017
- 30
- 2,795
- 3,433
- Chandler, Arizona
- Website
- www.KTuner.com
- 2017 Si
It's not.
Can you do that if you're running a race MAF housing or catless DP?You can indeed check for errors and OBD status with the KTuner software.
The only advice we can give related to emissions is to flash to factory.
So which system isn’t ready or set readiness?
my bad, evap. Is your car completely stock? Anything removed or performance upgraded other than the flex fuel kit?
That last comment about flex kit and ect2 could be it. Why not unplug flex kit electrically only (but leaving it in the car) then flash back to stock (taking dp off) to get readiness to set. Then revert after done.
Just had a thought for if this is the case... I may get a long pigtail and wire a dual in-line fuse holder, and wire the ECT2 and the Flex Fuel plugs in parallel, then I would just selectively pull the respective fuse to swap the active plug over. But.... that is really frivolous if unnecessary.... knock-knock PRL...That plug is a hard reach from up-top, and (IIRC) requires the shroud to be removed to reach...
If you are looking for assistance from PRL I would recommend contacting them via their official support channels. Unfortunately I don't think posting the text "knock-knock PRL" on a public forum will be particularly useful.Just had a thought for if this is the case... I may get a long pigtail and wire a dual in-line fuse holder, and wire the ECT2 and the Flex Fuel plugs in parallel, then I would just selectively pull the respective fuse to swap the active plug over. But.... that is really frivolous if unnecessary.... knock-knock PRL
@IronFusion, great idea if thats the case w the piggytail. So now hope it isnt the dp..?
If you don't have easily removable vents its still quite easy if you just go from underneath. If you don't want to take off the bumper if your car has the fog light little plastic flaps from underneath. You can just put your hands through there.I really hope it is not the key. That plug is a hard reach from up-top, and (IIRC) requires the shroud to be removed to reach. If I have to do that every year (annual inspection), I am inclined to remove the flex fuel kit with a vengeance and toss/sell it. Kind of hoping @PRL Motorsports can, again, inject some knowledge. I'm flying blind and panicking here.
