Post your aftermarket wheel/tire set up
Romka1982
Roman
Honda Civic
Tired of scrolling posts))) Just curious does someone have 18x8.5 35 offset with 245/45 tires?
TimLaura
Tim
Netherlands
Honda Civic 1.5 Sport+ Hatchback
Good afternoon,
I still can't figure out what size rims / tires I can get on my car. I have been in contact with Fitmentindustries and initially wanted to go for a staggered setup 8.5j front and 9.5j rear. However, they advise against this too strictly.
Now I am again faced with a dilemma and a question. I am now doubting to take 19x9.5 around. With a 245/35/19 tire ET+40. Unfortunately, I cannot see this setup anywhere. Could someone tell me if this will work? Without rubbing or scrubbing
I ride the 1.5sport + with the Eibach Prokit on it.
Sincerely
Tim
SonicBreezerST160
Tom
Everett, WA.
2017 Sonic Gray Pearl ST Hatchback
Good afternoon,
Sincerely
Tim
This was my car awhile back with an 18x9.5", 35mm w/ 235/40-18's. I am lowered on Eibach Sportline, and had no rubbing issues whatsoever.
Hope that helps you.
Honda Civic 10th gen Post your aftermarket wheel/tire set up IMG_20180305_165822
AmaiX
Maui, Hawaii
Civic Sport Hatchback
Good afternoon,
Sincerely
Tim
If you’re dead set on getting 19s, I’d even drop down to a 225 or 235/35. Don’t see many 19s on the forums, let me see if I can find any on FB.
Nozomi135
Josh
Moncton, NB. Canada
2017 Honda Civic Si (Modern Silver Metallic)
So pumped for better weather, ordered JNC033 in Black Chrome - 18 x 9.5 +35, going to run 245/40/18 Firestone Firehawk Indy 500's on Eibach Pro Kit. Car season can't come quick enough!
Honda Civic 10th gen Post your aftermarket wheel/tire set up 2_530x@2x
AmaiX
Maui, Hawaii
Good afternoon,
Sincerely
Tim
https://www.civicx.com/threads/fs-19x8-5-35-19x9-5-40-avant-garde-m590-wheels.9522/#post-159026
TimLaura
Tim
Netherlands
Thank you SonicBreezerS T160 & AmaiX.
in 2 weeks I have an appointment to fit different wheels / tires under the car. I will immediately order the rims that I want. As soon as they are underneath, I will post photos and explain what it turned out to be! Thank you for your responses.
bptruett
Ben
Knoxville, TN
18’ Civic Si Coupé
Hey guys, looking at getting the Enkei Tuning Series TSR-X Bronze rims in a 18x8.5 +38 offset. I also have some Firehawk Indy 500's at the house that are 235/40R-18. I don't doubt the tires will fit the wheels but if the rims will fit on my 2018 Si coupe. I asked multiple people on tire rack and they said they couldn't guarantee they would fit without rubbing issues. Anyone see any potential problems with this setup? I'm also considering running the Eibach Pro kit and a DIY brembo kit and was wondering if anyone thought there would be any issues running those too? I'll link the wheels at the bottom. Thank you all
https://www.tirerack.com/wheels/Whe...odel=Accord+1.5T&autoYear=2018&autoModClar=EX
SonicBreezerST160
Tom
Everett, WA.
You'll be fine on that setup, but personally I would get those wheels in the 18x9.5", 38mm fitment. The faces are more aggressive looking, you'd end up happier!
bptruett
Ben
Knoxville, TN
18’ Civic Si Coupé
Thank you! Stuck between deciding on those or the Enkei Dracos in 18x8+45 but not too sure. Already have tires so i can’t do the 9.5
SonicBreezerST160
Tom
Everett, WA.
You can mount 235/40's on a 9.5" wheel with no issues. In fact, that's a better setup. It will give you more fender lip clearance on the rear.
Photos are my STH
Honda Civic 10th gen Post your aftermarket wheel/tire set up IMG_20180305_174020
with 18x9.5", 35mm with the stock Continentals (235/40's).
The Continentals run skinnier (section width) than the Firestones also.
GixxerMKD
Baze
Macedonia
Honda Civic 1.5 Hatchback Sport 2018
Hi guys,
can anyone tell me if i got this right, i want to go with 19x9.5 +38, and i'm lowered on Eibach pro kit.
The setup i'm seeing here and like mostly is 18x9.5 +38, so the question is if i go inch up (19), will the spacing from the fenders be same as it's on the pictures with 18x9.5?
thanks!
SonicBreezerST160
Tom
Everett, WA.
Hi guys,
thanks!
Using a 235/35-19 tire on the 19x9.5, 38mm will put you at 25.5" outside diameter, which is .2" shorter than a setup I used successfully with 18x9.5 "wheels, 38mm &(245/40-18). Stock STH/ST & Si's came with 235/40-18's which are 25.3" outside diameter. I always try to stay close to that, and going over a bit is better than under, due to mileage acrual.
My STH is lowered on Eibach Sportlines, and required about -2° of rear camber to make the setup work w/o rubbing.
Hope that helps you out.
