Post your aftermarket wheel/tire set up
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
Gram Lights 57Transcend. 18x9.5 +38. Michelin Pilot Sport 4S 245/40x18
First...wow. Looks amazing
Second: what are you lowered on and do you have any rubbing? I’m considering same size wheels and offset
Thanks!
krtnchls
2017 Honda Civic Hatchback LX
Konig Dekagrams 18x8.5 +38 offset
Lowered on Eibach Sportlines
Wrapped in Yokahoma 225/45/18
Is this sport? Where did you get your skirts? Do you need to remove your stock skirts before putting those or you just attached everything?
T.Z
United States
2018 Honda Civic Hatchback EX
No mine is an ex. I got my skirts from downforce solutions. Im not sure about the sport, i don’t think you need to for certain skirts.
TC_Columbus
Todd
Columbus, Ohio
2019 ZR1 Corvette, '19 Civic Si Sedan
Thanks!
Thank you. I am using Eibach springs, with SPC adjustable ball joints up front and control arms in the rear. On the street there is no rubbing. On the track there is.
JT Si
Place
Car
Finally got my wheels after long a long wait!
18x8 Enkei Vulcans
235/40r18 Vredestein Quatrac 5.
Ride quality definately improved over stock tires and the car is noticeably heavier but not a major difference in mileage maybe 2 -3 mpg is lost. Overall I love the look! Thank you to @gtman for the advice!
Edit: found another post where you mention it's +45
I'm seriously considering these wheels on my MSM coupe. What offset is this? The +45 or the +35? Can you post a pic of the front brake caliper clearance behind the wheel?
These look great. I thought for sure I didn't want black on the MSM but you're making me reconsider.
CanadiaegeanBlue
Humza
Stupefyer
Sean
San Diego
2018 Civic Hatchback Sport
Work Emotion D9R 18x9.5 +23
255/35/18 Falken Pro G5 A/S
Lowered on D2 Springs
Rear fenders were pulled. Fronts are stock. No rubbing unless I hit a big dip or bump. :)
Honda Civic 10th gen Post your aftermarket wheel/tire set up 4B2F85AF-D914-4CFF-9DD5-B368A1BE12C0
Honda Civic 10th gen Post your aftermarket wheel/tire set up 9B60BEE5-4694-4A75-9F56-9CDEB486042E
Honda Civic 10th gen Post your aftermarket wheel/tire set up C6155410-9AE9-4E95-AF48-C11E52C48E4C
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
Finally got the new wheels and tires installed
AVID.1 AV-20's 18x9.5 et 38 wrapped in Firestone Firehawk Indy 500's 245/40/18
Only experience rubbing on hard bumps (test drove today and purposely hit bumps to see if rubbing would occur)
Lowered on D2 springs 2" all around.
Honda Civic 10th gen Post your aftermarket wheel/tire set up side 2
Honda Civic 10th gen Post your aftermarket wheel/tire set up front
Noobster
Jonathan
Fort Huachuca, AZ
2019 Civic Type R
Hello I just got rims,
57Transcends 18x9.5 + 38 I’m torn between tire sizes.
The recommended is 255/35/18 or 255/40/18.
And any recommendation on tires? I was going to do Advan R/S but seems a lot of people that the fire stone Indy500.
I’m not lowering the car or tracking just a daily driver but I also want it to look good... I don’t want any rubbing or lose much turning radius. Any info or assistance would greatly be appreciated! Thanks
BlueLdr
Eric
Maryland
2018 Civic EX Sedan (ABM)
Flow One F3 18x8 +45
Continental PureContact LS 225/45R18
Pictures don't do the paint on these justice, they look fantastic in the sun.
Honda Civic 10th gen Post your aftermarket wheel/tire set up 20190805_120112
Honda Civic 10th gen Post your aftermarket wheel/tire set up 20190805_115848
Honda Civic 10th gen Post your aftermarket wheel/tire set up 20190716_173321
Honda Civic 10th gen Post your aftermarket wheel/tire set up 20190805_120815
Honda Civic 10th gen Post your aftermarket wheel/tire set up 20190730_093356
Civic_Si_Yes
High Speed Low Drag
Riverside, CA
2018 Civic Si Sedan
I have the same size and offset wheels but I’m lowered on D2 springs (2” all around) and running Firestone Indy 500 245/40/18 and experience little rub. You could use the same tires and not have any rub since you’re not lowering them. They’re flush with the fenders as well and look good.
I was going to go with 255s but didn’t want the chance of rubbing. Again since you’re in stock suspension you should be fine.
