Post your aftermarket wheel/tire set up
702civic
Las Vegas
Civic touring
30 but I have seen others with a similar setup
Offset is the spacing from hub mating surface to rear of rim, that does not change weather it is 18" or 19" your +30 is just more aggressive than my front which is +40 and still more than my rear which is +35
dallasjhawk
Arlington, TX
2016 Civic EX-T, 2004 Acura TSX
I was told directly by wheel maker TSW that +30 offset would rub if you kept the correct plus sizing with your tires. You could make it work if you did the stretch tire look.
BarracksSi
DC
Yup. And 235-width tires would be fine on +50 offset, which is what our Sport/Sport Touring (and, now, Si?) models have.
imperialgrunt
Modesto, CA
'17 Civic Hatchback Sport Touring
Does anyone know if 18x8.5 +35 OR +40 wheels would fit the stock ST tires (235/40/18) without rubbing issues? I'm in the market for some new wheels, but am looking for something slightly more aggressive, but practical when I am hauling 3 other bodies in the car.
mikee_swoosh
Michael
Palmdale
2006 Honda Civic Si (Sold) 2017 Honda Civic Hatchback Sport (Sold) 2017 Honda Civic Type-R #117 PMM
yes they will
im running stock size: 235/40/18 wheels are 18x8.5
dallasjhawk
Arlington, TX
yes, its the 8.5 that matters and 235 will fit it.
nathanzachary
US
2020 Civic Si, 2004 Integra Type-R
That is exactly what I want stylistically (the Accord Sport rims), but I worry that they will decrease the ride comfort and noise. I don't think that there is much better of a look out there, but I've gotten really used to the smooth and quiet ride. What are your thoughts?
702civic
Las Vegas
Civic touring
you will feel the road more and road noise will depend on tire choice.
bembol
SHIFT_
Rafael
GTA
17 FK7 Sport Touring, 20 Audi Q3 Progressiv
+1 is the safest when upgrading wheels. Not to mention the cheapest.
As for road noise, you get what you pay for.
dallasjhawk
Arlington, TX
I dont feel like my road noise went up when I went to 19s on 235/35-19. I went Nitto Motivo and to me the noise is the same, if not a little better. Although i do have a 5 year old constantly talking so maybe that distracts me from the road noise. But you do feel bumps more.
drumachine9
illinois
2016 civic touring
I can't say I notice a difference in ride quality or noise. Love the look, it does rub on the fender liner when I turn the wheel all the way to one side or the other, like barely. Was considering sportlines but that might be to much drop so I'll probably get the less aggressive ones so I can get it to sit flush.
airickmatthews
Ruskin fl
17 civic hatch sport
Hey guys, I came across a good deal on a set of wheels. They're 18x9.5 +35. I'm concerned about the fitment as I don't wanna run a stretch tire. So I'm looking at a 255/40. Anyone running these numbers or can shed some light? Worried about the fronts and if I'll hit the struts.
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
2012 Acura TL California Edition / 2018 Civic Si Coupe /2020 Civic Type-R
You will be fine with a 35mm offset in the front with a 9.5" width rim.. you still have about 1/2' more to play with against the front strut, now on the tire.. that should be pretty square on the rim with a 255/40... might want to try a 255/35 since the tire might be a little bit taller. I have seen a 19x9.5 45mm work in the front but I think the person in instagram said that they have only 3~4mm clearance with the rim against the strut.. but he was dead flush up front but he was running a 245 series tire so that might have helped:hmm:
dallasjhawk
Arlington, TX
check this
