Post your aftermarket wheel/tire set up
djsalty
Gábor
Hungary
2021 Honda Civic 1.5T Hatchback Sport Plus
Advan Racing RGIII (UBM)
18x8+37
Yokohama BlueEarthEs
235/40R18
(Total 50lbs reduction, i.e.12.5lbs/wheel)
Lowered on Eibach Pro-Kit
Hi,
I would like a new wheel setup but I can't decide between 8x18" ET40 or 8,5x18" ET35 with 235/40/R18 tires. I have the 2021 Civic Hatch Sport. I saw that You have almost the same size with 8x18" ET37 with 235/40/R18. (Only 3mm diff.) I also would like the Eibach Pro kit later.
I would like Your opinion about the daily drive with this setup You have. I guess no rubbing with this, but what if You have some package in the trunk or 4 people in the car? How much the wheels are poking out if You check it from the front or back? Any problem with rock throwing to the side? Thank you in advance!
GoldClass
Singapore
Civic Hatchback
Hi,
18x8.5+35 wrap with 235/40R18 is dead flush and perfect fit with pro kit. I settled 18x8+37 is b’cos I love Advan Racing RGlll design but it does not have size of 18x8.5+35. No rubbing or whatsoever when 4 pax load on pro kit but the life of oem shock will be short lived ~3years. That’s said, you can consider SI spring, it has a slightly higher spring rate and also just slightly lower than oem (can’t recall how much lower).
djsalty
Gábor
Hungary
Thanks for the info! How long do You have the Pro kit? Did You change the factory shocks yet?
Did You have any problems with the Pro kit? I'm reading about strange noises in the forum about them.
GoldClass
Singapore
Civic Hatchback
It was installed by Eibach authorized installer and have been driving for two years with oem factory shocks. No noise but I can feel that the oem shocks are now getting softer than before. Prior upgrade to pro kit, the factory shock have been working for 2 years. In total, 4 years on factory shocks till today. It is due to replace the shocks and service the entire suspension system to replace the shocks and tighten up all the bolts back to spec.
djsalty
Gábor
Hungary
Thanks for all the help, I appreciate it!
Tyler.iguess
Tyler
Harrisburg, PA
2017 Civic Si coupe
First pic, 18x8 +45 enkei tm7. 235/40/18 firehawks
2nd pic, regen5 18x8.5 +38 255/35/18s
04sthemi
FL
2020 Civic SI, 2018 Jeep GC, 2004 Dodge Ram 1500
Just put on some new Enkei TFR’s. Stock suspension, 8.5x 18”+38. Michelin pilot sports-255/18/40’s. Rides like a dream
That looks meaty as shit! I love it.
04sthemi
FL
I feel it has an even more aggressive stance, even on stock suspension. Thanks for the compliment ????
I want to do an aftermarket setup but would like to stay stock height, that tire size Ill prob mimic
KOIVUN1
Steve
Chicago
2020 Si CBP
Volk CE28SL 18x8.5 +35
Michelin PS4S 235/40/18
Lowered on Eibach Sportlines
Definitely want to drop a bit lower, especially the rear, so plan on moving to coilovers.
you could switch to 245/40 instead of lowering more, the extra sidewall could achieve the fitment you're after
