nickname
- Apr 20, 2019
- 89
- 979
- 364
- Houston
- '16 Civic Touring
Thanks for understanding. I get very technical sometimes. When I had my Jetta LED'd out I always had problems. LEDs don't have resistance so I had wire in the correct resistor for each LED. Additionally, the interior dome lights would slowly dim when doors were shut, the LEDs just flashed. hahaYou're writing detailed paragraph after paragraph, but we're talking a simple swap of a plug and play light bulb here. I get it, for you that's a "risk". For me and many others, it's a simple upgrade to improve nighttime visibility and match the white light of the DRL's.
1. Reliability does not mean "last forever", reliable means you can buy them anywhere; Wal-Mart at 3 a.m. so you don't get pulled over riding dirty. Reliability also means you can afford them. So, when the inevitable happens, you can rely on finding this bulb and affording it. Versus high-end cars with expensive HIDs and ballasts.One of my stock headlights burnt out after 35k miles. Super reliable indeed.
Also, if you were to choose an LED that uses the same voltage etc how is that any different than the stock? Makes zero difference, doesn't add strain to the stock electrical system and I'd be willing to bet the ecu does not see any difference. I do respect your opinion on keeping it stock for reliability, but to state that you should NEVER swap anything over from stock because it becomes less reliable is spreading false information.
Now if you said, make sure the voltage etc lines up and to not get ebay trash then yeah awesome.
2. Voltage is not wattage. Imagine a water hose; the AMOUNT of water is voltage (measured in volts), the CURRENT is pressure (measured in amps), the RESISTANCE at the nozzle (measured in ohms) dictates how much volts and amps need for water for spray at the appropriate rate. Having the correct voltage rating means nothing, it comes down to ohms and how much amps the car's computer is sending and receiving feedback. Again, LED are diodes, electricity only flows one way. Incandescent are either in series or parallel, which would confuse the modules.
If our car was a Hyundai, I wouldn't worry about this. But it's a Honda, I know they're using more advanced communication systems.
and thanks respecting my opinion about OE parts (it used to be my job as an advisor to sell OE parts, and I did very well)
all I'm saying once you change from OE to aftermarket, you become the Chief Engineer of your car
