Polk 8 inch subwoofer not making any bass... vibrates like a dying sex toy
dirtrider216
2017 Hatchback Sport Touring, 2006 4Runner (for sale)
Just tried to install a polk db842 8" DVC subwoofer in my sport touring with the 12 speaker system. At this stage the subwoofer was just a drop in replacement. I dont have an aftermarket amp or a line out converter. Just spliced the oem wiring harness for the stock subwoofer. got everything connected and then turned on the car to test it. The subwoofer cone vibrates about as much as a dying sex toy. There is absolutely no sound output from it at all, even with subwoofer and bass turned all the way up in the headunit EQ.
Do I have a dead subwoofer or is this simply due to the sH*t EQ from the vehicle DSP?
I stupidly already tossed the oem sub so plugging that back in isnt really an option..
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
When you say 'absolutely none'; do you mean the shit is weak? Or do you mean that, if you touch the surface, there's zero vibration felt?
dirtrider216
It just barely vibrates.
It moves but doesn’t make any bass
Ocelot
Ben
Manitoba
'16 EX-T sedan, '12 LX sedan
Are the coils wired out of polarity with each other
shoegazer
Raleigh NC
That particular sub, I believe, only has one set of terminals. And even if it is out of phase with the other speakers; you'd still feel it vibrate (when touching it). I'm guessing that there's just not that much 30Hz-200Hz signal coming from the Honda system. But I'm just guessing.
Ocelot
Ben
Manitoba
I’m sorry, I was sure I read somewhere that it was a DVC.
PandaXpress
EX-T with Honda Sensing
nope the db842 is a DVC and has two sets of terminals
dirtrider216
I only have one set of terminals connected because I thought the oem system was 4ohm
Do I need to wire the sub as 2ohm for it to have enough power?
Kane666
Jason
Pennsylvania
2018 Civic Sport Touring
the dsp will cut it off anyway once you get it. it needs to be the same ohms.
PandaXpress
you shouldnt run only one coil for a dual voice coil it might damage your woofer
you need to wire it in Parallel, so it will be running at a 2 ohm
Phy
TN
I'm interested in what kind of improvement you get from just replacing the sub.
dirtrider216
Went back and rewired it like that.
It made a small improvement but I still can’t tell a difference between having the sub plugged in or not plugged In
