Please help me find metal tapping noise
Crakzor
Mathanael
DFW
2014 Chevy Cruze, 2020 Civic Si
I'm hoping someone can recognize this noise.
I have MAP exhaust, and PRL CAI
It's been happening a while now. I notice it more at the drive thru . It's not just when im turning. It's also when im going straight. If its the exhaust I just dont see where the exhaust could be making that noise.
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
To my ear... that sounds like something really small bouncing around inside or on top of something larger. Maybe a pebble or something similarly hard/solid? The first thing I'd do is take off the metal cover underneath and see if there's something bouncing around there. Also... folks have been known to find very small pebbles inside the rotor covers.
It's louder at the drive-thru because the sound is bouncing off of the brick walls.
Good luck. And let us know what you find.
1981CBX
William
United States
2017 Honda Touring Coupe (owned) 2018 Accord base model (leased) 1981 Honda CBX motorcycle
Its probably the sound of a VAG product trying to get out
vtecr
FK
Eire
FK7 GT-Spec Daily, EP3 Type-R, EP1 Project, EU7 Beater (+ others I care less about...)
Kinda sounds to me like a stone stuck on the control arm or behind the brake shield.
Does it ever do it when you're not moving?
Crakzor
Crakzor
Mathanael
DFW
ok ima do tire rotation tomorrow and see
AngryLettuce
Badger
Great Britain
2021 Type-R
Brake pad retaining springs?
Brake disc splash guards/shields?
You need to jack the car up and spin the wheels by hand.
Imagine how much money you could make if you could diagnose weird sounds from viewing a video clip..................I'm sure I heard a cat meow on the second vid, is it trapped in the intake?
zspeed
Camden County, NJ
Had the same thing that happened to me before.
Thought it was the endlinks, brake shims, rotors discs, pads. It just came to one root cause which was a small debris that was left inside the tire when Costco mounted my new tires.
Crakzor
Crakzor
Mathanael
DFW
Did tire rotation front to back and back to front
the sound is now in the rear. So something is definitely insidethe tire from When discount tire mounted it
zspeed
Camden County, NJ
There you go man! Same case with mine. Lol!
Crakzor
Crakzor
Mathanael
DFW
It was this rock in the tire thanks y’all
Honda Civic 10th gen Please help me find metal tapping noise 608870D7-A066-4CCE-A1C7-6120FC7C7996
