PIDs for Torque/Torque Pro?
odinist
Matt
OKC
www.mithgarthr.com
2018 Aegean Blue Si Sedan
I got a Bluetooth OBD2 dongle in yesterday, and setup an old phone to use as a dedicated screen for Torque Pro. However, I've found a goodly amount of sensors that don't work (like IAT and coolant temp). I was wondering if anyone had a list of the PIDs for different sensors for Honda?
  • Like
Reactions: Myx
Dimitron84
Patrick
Youngstown, OH
2018 Civic SI
I'm in same boat as you, can't get it to work either, according to ktuner they are standard pids
baldheadracing
Craig
Canada's capital
FK8
Download:
TorqueScan (Torque OBD Plugin)
from the Google Play Store. The plug-in is by Ian Hawkins. (You need Torque Pro for plug-ins to work.) The plug-in will scan your PID's to find what's active.
odinist
odinist
Matt
OKC
www.mithgarthr.com
  • #4
Download:
I've seen this mentioned, but haven't tried it yet because I'm lazy AF.
Can you confirm this works?
odinist
odinist
Matt
OKC
www.mithgarthr.com
  • #6
Dude, RAD!!
Thank you!!
Dimitron84
Patrick
Youngstown, OH
2018 Civic SI
Dude, RAD!!
Thank you!!
I tried it tonight and it still does not work, installed lan Hawkins plugin as recommend and there is no data for Intake Air Temp or Coolant? Even tried running the extended PID and it didn't find any.
odinist
odinist
Matt
OKC
www.mithgarthr.com
  • #8
Same. The plugin did look to pick up a few things, but IAT and coolant are still dead.
Dimitron84
Patrick
Youngstown, OH
2018 Civic SI
Any other recommendations on this? Still cannot get IAT or any other important readings. Tried iOS and android and several different obd dongles including Bluetooth and Wi-Fi.
Birga
Calvin
Southeast Alabama
2018 Civic Sport 6spd
Ironically, I have an old install of Torque from my VW TDI a few years ago on a tablet. The coolant temp works on it.
Coolent Pid: 0167 Equation b-40 auto, that should give you the engine coolant temp sensor. I'll go through the rest later today and post what else works.
Dimitron84
Patrick
Youngstown, OH
2018 Civic SI
That's awesome, I was able to get coolant to work on dash command, however cannot get intake temp to work
Birga
Calvin
Southeast Alabama
Okay, IAT is apparently PID 0168, -40 to 300, unit (the little degree symbol) C, b-40. with that I get an IAT of 122F and giving it a bit of throttle it drops to 120F, which with a turbo seems about right.
I'm going to try a range of -40 to 215, and an equation of a-40 later, I'll update if it works better
Dimitron84
Patrick
Youngstown, OH
2018 Civic SI
I can test any pids or variations you need me too, can you explain what difference a-40 and b-40 means? I quite don’t understand them, also will range make sensor read diff? I thought it was just a dial range? I also have the Auto Scanner so will be able to confirm true readings... I know we have 2 IAT sensors and 2 ECT sensors, see below pic.
Dimitron84
Patrick
Youngstown, OH
2018 Civic SI
Also did you test out and get the 0167 pid to work for ECT that was posted here?
Birga
Calvin
Southeast Alabama
I did the 0167 works, entering a-40 as the equation makes the IAT read -31ish degrees so no good there. Near as I can tell the range is just the numbers on the dial, as to the 'b' and 'a' in equation I don't know but it seems to be absolute or relative numbers from the sensor.
